D15 VTEC swap question?
Old Apr 13, 2006 | 04:17 PM
civickid5835's Avatar
Default D15 VTEC swap question?
I have searched and have found no results. I currently have a 90 Civic DX stock and want to swap a D15 SOHC Vtec into it. Will I need motor mounts or shift linkage? How do you hook up the VTEC?, do I need to convert it to OBD1?
Any help is appreciated.
Thanks
Old Apr 13, 2006 | 04:35 PM
g-ride-si's Avatar
Default Re: D15 VTEC swap question? (civickid5835)
you didnt search too hard, i typed in sohc vtec and searched archived contenet and got 113 results.
https://honda-tech.com/zerothread?id=1519185
Old Apr 13, 2006 | 07:24 PM
bobbyg crxh22's Avatar
http://rywire.com/store/produc...1d5e2
yours is dpfi right if not i bet its still on that site
they great thing is they do it right
Old Apr 13, 2006 | 08:02 PM
si0385.'s Avatar
stock motor mounts work and so does the shift linkage... you dont have to but i highly recomend converting to obd1, and using the correct ecu a p08 or a chiped p28
i have the d15b with a p05 ecu socketed and converted to vtec and its a strong motor for the money...
Old Apr 14, 2006 | 12:06 AM
FOMULA91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickid5835 &raquo;</TD></TR><TR><TD CLASS="quote">I have searched and have found no results.=Google
I currently have a 90 Civic DX stock and want to swap a D15 SOHC Vtec into it.=Sure
Will I need motor mounts or shift linkage?=No
How do you hook up the VTEC?, do I need to convert it to OBD1?=Yes
94cd5c_me_go
Nov 9, 2012 01:46 PM
robs93civic
28
Apr 24, 2006 03:46 PM
Simon Tibbett
24
Dec 7, 2004 03:31 AM
B_CRUZ!
Jun 25, 2003 09:39 AM
