Can I get a beter ride in my teg?
I have a 90 DA lowerd with tokico "blue" struts. Its not totaly slammed like I see most cars, but the fronts are like less than 1" away from hitting the bumpstops on the shock when car is on the ground. Almost every bump I hit, hits the stop. Is there any way to extend it any without raising it. Maybe better shocks?? WHat would you all recomend. Thanks
first off, u have to cut the bumpstops in half when lowering you're vehicle. and second, use a good brand strut and spring.
for example: i have kyb adj. struts with eibach sportline springs, i also cut one coil from front springs. rides like a dream
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dahoopdahup »</TD></TR><TR><TD CLASS="quote">Tokico is an all right brand. Why did you cut your coil?</TD></TR></TABLE>
im guessing he cut it to make it lower??
blackeg
Suspension & Brakes
Jul 23, 2008 09:43 AM
black_4cyl
May 23, 2007 02:40 PM
