Where is the best place to buy a TODA clutch kit Full Face?
Old Apr 13, 2006 | 02:41 PM
01PYTypeR#1140's Avatar
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Default Where is the best place to buy a TODA clutch kit Full Face?
Where is the best place to buy a TODA clutch kit? The full face TODA clutch kit including a TODA lightweight flywheel, clutch disc, and pressure plate. The entire assembly balanced? I found it at Toda for $970.00, but I hope someone on Honda Tech knows where I could pick it up for less. Thanks!
Old Apr 13, 2006 | 02:47 PM
RTW DC2R's Avatar
why do you want the toda clutch? there are so many other cheaper options.
edit: with flywheel, thats not too bad IMO.
Old Apr 13, 2006 | 04:36 PM
baonest's Avatar
Default Re: Where is the best place to buy a TODA clutch kit Full Face? (01PYTypeR#1140)
ive got a toda flywheel forsale that has 10K miles on it. if you are interested
Old Apr 13, 2006 | 07:47 PM
ITR#132's Avatar
For a $100 more you can get this:
Toda Single Clutch
Old Apr 13, 2006 | 08:07 PM
Default Re: Where is the best place to buy a TODA clutch kit Full Face? (ITR#132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">For a $100 more you can get this:
Toda Single Clutch </TD></TR></TABLE>
What's the info on this? Why would it be worth wild stretching for it?
Old Apr 13, 2006 | 08:39 PM
ITR#132's Avatar
Info from http://www.todaracing.com:
Improvement in Clutch Response
A strap drive system connecting the pressure plate to cover is employed, improving the response of the clutch pedal operation.
A low Intertia disk
A high friction value, low wear rate, and a metal material with a high heat resistance made into a compact size (200mm). Giving you a high power transfer capacity and a long life. A small damper disk specially designed, and optimization of the metal pad including its thickness. Greatly reducing intertia to below that of the original product. Giving enhanced shift feeling and reducing wear on the gearbox.
High quality, Chromium Molybdenum Flywheel
Stress Analysis, balance, and inertia are simulated using CAD solid models for optimized performance. An overall design, designed to give good weight savings and low rotation characteristics.
If your looking to spend $970 on the Toda Clutch Kit; you might as well spend an extra $110 and get the High Power Single Clutch. Smoother, Faster, more precise shifting. But, it is a puck style clutch.
Old Apr 14, 2006 | 03:52 AM
Black R's Avatar
25 Year Member
.....well it certainly looks cool.
But I wonder how much power it can actually hold.
And what is the total weight of the kit including pressure plate, clutch disc, and flywheel?
Old Apr 16, 2006 | 11:21 AM
sinister6's Avatar
Im also wondering how much miles until it worn out.. both my ORC and OS last less than 10000 .. im going back to Excedy 750kg for the price reason, and its about time to change again.. im struggling in between a ACT and the Toda..
Old Apr 16, 2006 | 05:36 PM
Blind-Fashion's Avatar
I have one with 3k on it. With flywheel, 450 shipped
Old Apr 16, 2006 | 06:09 PM
Default Re: (Blind Fashion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blind Fashion &raquo;</TD></TR><TR><TD CLASS="quote">I have one with 3k on it. With flywheel, 450 shipped</TD></TR></TABLE>
Toda Single Clutch?
Old Apr 16, 2006 | 06:55 PM
The full face 970 dollar one. Not the 6 puck.
Old Apr 16, 2006 | 07:28 PM
Black R's Avatar
25 Year Member
.....that's a decent price actually.
Old Apr 16, 2006 | 07:31 PM
JjuuN R's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">
.....that's a decent price actually. </TD></TR></TABLE>
better then a decent price
Old Apr 16, 2006 | 09:54 PM
To be honest... I dont think the clutch is worth it other then the name :-/ but i did like it.. Grabs nicely. but man, the price is just outragous
Old Apr 17, 2006 | 09:38 PM
ITR#132's Avatar
Default Re: Where is the best place to buy a TODA clutch kit Full Face? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">.....well it certainly looks cool.
And what is the total weight of the kit including pressure plate, clutch disc, and flywheel?</TD></TR></TABLE>
That your going to have to ask toda. I would assume its specs are the the same or similar to the Exedy hyper single.
inkong
Jan 29, 2007 09:44 AM
EG civic hatch
Jan 28, 2004 09:38 AM
BoostedGSRBubble
Sep 15, 2002 09:50 AM
the big ragu
Jun 20, 2002 09:24 AM
