My car starts then dies halfway up to idle.....Main Relay???
Old Apr 13, 2006 | 09:42 AM
advanZC's Avatar
Default 88 ZC: My car starts then dies halfway up to idle.....Main Relay???!!!
I have an 88 ZC CRX and the motor was swapped last summer. The car has been running beautiful and then all of a sudden the other day when I start my car it dies or cuts out at about 1000 RPM on its way up to high idle. It's getting fuel and the intake is not obstructed. I am almost 100% sure its something electrical or I have a bad sensor somewhere. If it is the main relay then where is it located?? Does anyone have any ideas? Im running the 89 teg ECU by the way. I need to get my car running ASAP and I have limited funds.
Old Apr 13, 2006 | 11:12 AM
Ak_ef9's Avatar
Default Re: 88 ZC: My car starts then dies halfway up to idle.....Main Relay???!!! (advanZC)
maybe map sensor?
Old Apr 13, 2006 | 11:46 AM
EF_9's Avatar
dizzy??
Old Apr 13, 2006 | 04:42 PM
g-ride-si's Avatar
to see if its the relay, smack the relat with a screwdriver when it starts to die. if that keeps it from dying then your relay is bad.
Old Apr 13, 2006 | 04:47 PM
mattb1's Avatar
Default Re: 88 ZC: My car starts then dies halfway up to idle.....Main Relay???!!! (g-ride-si)
could ber your ignitor. small square thing on the inside of you dizzy w/four wires connected to it. I have owned two crx's HF & SI and this part has gone out on both with the syptoms you descibe. $100 part from the dealer
Old Apr 13, 2006 | 05:00 PM
civic_dork's Avatar
If the tach drops to zero before the motor actually stops spinning.... check your ignition switch out.
--- wish someone had told me that, just spent 300 bucks on a new dizzy... didn't fix it... 60 bucks on a switch fixed it. Mine, when bad, had to barely hold the key from returning from start (basically play with the key)... but not with starter engaged, then it would run.
tangerinebeast
13
Apr 13, 2019 06:03 PM
my2sons
12
May 16, 2007 12:33 PM
lilbastrd
Nov 4, 2005 08:56 PM
russian_racer
Jun 16, 2003 09:05 PM
chirp2hrd
12
Sep 8, 2002 06:47 PM
