Need help with jdm hid asap
well my buddy is doin my headlights now, we followed the instructions i found on mases install guide, and the headlights arent working, but the turn signals are
i could use some help, anything you could suggest whould be awesome
thanks
eric
thanks
eric
yeah....check the power, check grounds and also check the fuse box / fuse holders for blown fuses....verify that your bulbs are good....should be a simple fix...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotenITR »</TD></TR><TR><TD CLASS="quote">yeah....check the power, check grounds and also check the fuse box / fuse holders for blown fuses....verify that your bulbs are good....should be a simple fix...</TD></TR></TABLE>
Yes the fuses.....must check the fuses. I believe stock ones are 10amp. If you've got those...those won't work. Some here have posted they upped it to 20 and so forth. I'm using 30amps and they've worked just fine with no problems.
too cool
thanks alot
do you think you could email me the original that doesnt have the we-todd-did tag on the bottom left
thanks
eric
thanks alot
thanks
eric
Thank you so much! That wiring diagram is exactly what I need! The only issue is the push-button switch. I have two wires running out from it (red and white) that split into 3 (yellow and 2 black wires I think). Anyways, regardless of their colors, I'm assuming one hooks up to the battery, the other to the relay (like in the diagram), and the last one to the chassi as a ground wire (not 100% sure, but it would make sense). Right now my push-button switch isn't hooked up to the battery, so that's part of my problem. Thanks
