Removing wheel stud
Old Apr 13, 2006 | 05:48 AM
x_tc-Dae's Avatar
Default Replacing wheel stud
When i was changing my winter tires to my summer tires, some how i broke my wheel stud while i was taking the rim off Does anybody have any idea of removing the wheel stud? Do i have to take the hub assembly out?
Modified by ghost face at 12:46 PM 4/13/2006
Old Apr 13, 2006 | 11:44 AM
x_tc-Dae's Avatar
Default Re: Removing wheel stud (ghost face)
Called the Stealership and they said it would cost around $120 for 2 wheel stud replaced What a rip off. Previous owner had the hub bolt stripped for some damn reason so i might have to take it there Unless some one have a suggestion??!?
Old Apr 13, 2006 | 11:50 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
you can just take the hub off and take it to a shop to have pressed, or you can get ghetto like I did before and use a HAMMER!!!!
BIGGIDYBOB's Avatar
is it the front or rear studs that need replacing? the rears would be much easier since you would only have to remove the caliper, rotor, then the hub bolt and take the hub out. from there just hammer the damaged studs from the face of the hub.
If it was the front you would have to press the hub out of the knuckle to get the studs out. i learned the hard way hope that helps a lil
Old Apr 13, 2006 | 12:03 PM
x_tc-Dae's Avatar
Default Re: Removing wheel stud (BIGGIDYBOB)
Its the front driver studs that need replaced. Yea i think i might have to be ghetto on this and hammer that out.
streetracer_305
18
Jun 20, 2015 01:59 PM
cmfnelson
Nov 24, 2012 01:03 AM
christiantequila
Dec 22, 2008 08:11 AM
fit2slo
Honda Fit
Oct 28, 2008 10:56 PM
integraRS-T
Nov 15, 2007 11:17 PM
