Need help with lowering teg. Plz help!!
Old Apr 12, 2006 | 09:59 PM
2.2 teg's Avatar
Default Need help with lowering teg. Plz help!!
I have a bit of a problem. I'm trying to remove my rear struts. But, the bolt going through the trailering arm and strut is like rusted shut. How the hell can I get this out? Do I need to replace the trailering arm? If so, anyone know where to get them super cheap?
I have tried: air gun, and drilling the bolt. Should I try to torch the bolt?
This is a major headache b/c I JUST got my H22 running and only got to drive it once so any help ASAP would be appriciated!
Old Apr 12, 2006 | 10:54 PM
BlueIntegraBoy's Avatar
Default Re: Need help with lowering teg. Plz help!! (importtunerboy)
You mean the strut to the LCA? Torching would help but you will then need new bushings. Try using PB Blaster, I heard it works great against seized bolts.
Old Apr 12, 2006 | 11:40 PM
97tegGS's Avatar
You can find rear arms for 100 Shipped. and a new bolt from the dealer will work.
I anticipated the problem and used omni rears and a 3/8x16x2.5 or 1.5 grade 8 bolt with a washer on each side, some antiseeze and a locknut instead of the OE bolt
civicdelsol33
Suspension & Brakes
Dec 17, 2007 09:45 AM
Usdmowns
Sep 9, 2006 12:26 PM
2wheelhunter
Sep 3, 2006 10:00 AM
Speed94
Mar 30, 2006 07:13 PM
boostin4drcivic
Apr 18, 2004 03:57 PM
