Pinch bolt on shock fork not coming off
Old Apr 12, 2006 | 05:10 PM
coot_er's Avatar
Default Pinch bolt on shock fork not coming off
im trying to install new suspension in my rex (it's an hf if that matters). i have the shock assembly out but i can't get the pinch bolt loose. i have sprayed it with pb blast and taken an impact to it several times and it wont budge. i need it off so i can get my car on the street.
Old Apr 12, 2006 | 05:34 PM
fireant's Avatar
Default Re: Pinch bolt on shock fork not coming off (coot_er)
If you completely remove the bolt from it, you can wedge a fat old junky screwdriver into the gap and pry it apart.
You'll find the brake line brackets are what are REALLY hard to get off the shock tubes.
Old Apr 12, 2006 | 05:38 PM
hotboxedcrx's Avatar
Try heat, Penetrating fluid soaked overnight, and a firm hit with the hammer may begin to free it up.
If you take your time, you will avoid future head aches (snapped bolt resulting in drilling and easy out, or tapping.)
Old Apr 12, 2006 | 06:31 PM
Crx Jimmy's Avatar
just put a little penetrating oil on then keep using the impact going in reverse <U>and</U> then forward again( make sure you are using a impact socket not a regular socket) it will eventually get loose
Old Apr 13, 2006 | 07:13 PM
coot_er's Avatar
Default Re: Pinch bolt on shock fork not coming off (Crx Jimmy)
why would you put it on forward?
Old Apr 13, 2006 | 07:33 PM
1989CivicSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">why would you put it on forward?</TD></TR></TABLE>
Lower the changes of snapping/breaking the bolt. 15+ years of salt and rust does wonders.
Make sure to spray the threads of the bolt down with a bit of penetrating fluid before driving back in every time you drive the bolt out. That way you'll be driving a bit more penetrating fluid into the threads each time thus making it easier on the old bolt to come out.
Old Apr 13, 2006 | 07:52 PM
si0385.'s Avatar
i would start with heat... it might ruin the seals in the shock though you could probaly get away with it if you are careful
rhennin
Suspension & Brakes
12
Apr 12, 2007 12:16 PM
unhappy_idle
May 16, 2006 09:22 AM
libby12060
Jun 19, 2004 03:31 PM
is3oo
Oct 4, 2003 01:48 PM
Batoutahell
Oct 15, 2002 04:33 AM
