Help with B16
Old Apr 12, 2006 | 04:28 PM
strictlyimport's Avatar
Default Help with B16
I am having problems with B16 swap. Car bogs at wot at normal operating temp. All wireing was done with Hasport. Changed TPS with known working one, map sensor is good. What could this be? All honda gurus pls chime in. Thanks
****update****
Dizzy, plugs, plug wires have all been changed. Timeing has not been touched, fuel filter new and exhaust is not clogged, all have been changed. Car runs perfect when cold, idles perfect when cold and normal operating temp, only problem is when it gets to normal operating temp at wot.
Modified by strictlyimport at 5:54 PM 4/12/2006
Old Apr 12, 2006 | 04:46 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
Check your throttle cable, and if that's not the case, it's probably a fuel problem.
That avatar is broken by the way.
Old Apr 12, 2006 | 04:47 PM
Malgerus's Avatar
Default Re: Help with B16 (strictlyimport)
sounds like an ignition or a fuel problem.
any blockages in the exhaust?
Old Apr 12, 2006 | 04:49 PM
One more thing: Fuel problems tend to compound themselves and get worse with time.
By the way, when was the last time you changed the plugs and wires?
Old Apr 12, 2006 | 04:51 PM
mar778c's Avatar
Community Builder
Community Influencer
check timing and dizzy. ODB0 dizzys are notoriously unreliable.
biglebowskicivic
38
Mar 17, 2021 12:38 PM
B16acivicsedan91
Feb 28, 2008 09:39 AM
Bustinvtec
May 30, 2006 01:19 PM
hatchish
May 2, 2005 10:31 AM
DOHCRX
May 13, 2003 01:50 PM
