Koni yellows make rear sit lower?
Old Apr 6, 2002 | 04:38 AM
Razor's Avatar
Default Koni yellows make rear sit lower?
For the 5th gen owners with koni yellows, did the rear sit lower after you installed the yellows? i had neuspeed sports with stock shocks and my height in the front and back was equal, now the rear sits lower. is this normal? i set all teh settings liek the damper and height settings as teh way they came out of the box.
Old Apr 6, 2002 | 05:02 AM
Razor's Avatar
Default Re: Koni yellows make rear sit lower? (Razor)
oh yeah another question
do the shocks come full soft when they come in the box?
should the wheels be off the ground when i adjust the shocks or it doesn't matter? can the front 2 have different dampness compared to the rear 2?
Old Apr 6, 2002 | 05:21 AM
urbanlegend21's Avatar
New User
yes they will make the rear sit lower
no you do not have to adjust them while the wheel is in the air
if you cannot tell the setting out of the box then send them back, did you get an adjustment tool with them?
yes you can set them at two different dampers front to rear, I run my rear full stiff and front 3/4 to 1 turn from full soft
Old Apr 6, 2002 | 09:51 AM
Razor's Avatar
Default Re: Koni yellows make rear sit lower? (urbanlegend21)
yes i got 2 adjustment tools, i just didn't check to see if they were set at full soft from the factory. i just installed them the way they were and was planning to adjust them later.
Old Apr 6, 2002 | 10:02 AM
Nick M's Avatar
Mine were at full soft from the factory. The rear does sit alittle bit lower. But also stock my rear looked alittle bit lower. So i think its all relative. How much did u get them for?
Old Apr 6, 2002 | 01:40 PM
Razor's Avatar
Default Re: Koni yellows make rear sit lower? (HondaSport)
554 from shox.com, all 4 adjustable
so what is the best way of adjusting them? is there anything special you do?
Old Apr 6, 2002 | 02:46 PM
Razor's Avatar
hey guys im trying to adjust my rear struts and there is no room for the **** to go on the screw, the **** is too big. what should i do? please help ASAP
Old Apr 6, 2002 | 02:51 PM
Razor's Avatar
please help me out, im dong it right now, thanks ^^^
Zaraki
Suspension & Brakes
Apr 15, 2012 02:56 PM
Asahi
May 18, 2002 05:29 AM
coop94ls
Jul 31, 2001 09:56 PM
MintyDip
Jul 8, 2001 05:25 PM
