2000 SI head! assistance please!pic*
Old Apr 12, 2006 | 12:55 PM
gmadsen100's Avatar
Default 2000 SI head! assistance please!pic*
i've got a 1992 acura integra LS and i just got a 2000 si head for LSvtec conversion. while lookin at the motor i tried to take the valve cover off and had some problems. heres a picture
[IMG][/IMG] <center>
</center>
i tried giving it a little wd40 lube job but no such luck.. what to do!!!!help!
Old Apr 12, 2006 | 12:56 PM
Rajin's Avatar
Default Re: 2000 SI head! assistance please!pic* (gmadsen100)
Work on your Image placement skills.
Old Apr 12, 2006 | 01:02 PM
Lan's Avatar
Lan
Don't worry about it.... Just grab the piece with a pair of pliers and unthread the nut.
Old Apr 12, 2006 | 01:05 PM
Wayne_Curr's Avatar
Default Re: 2000 SI head! assistance please!pic* (Lan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lan &raquo;</TD></TR><TR><TD CLASS="quote">Don't worry about it.... Just grab the piece with a pair of pliers and unthread the nut.</TD></TR></TABLE>
Dont strip threads though
Old Apr 12, 2006 | 01:06 PM
psychotic_z's Avatar
Default Re: 2000 SI head! assistance please!pic* (Rajin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">Work on your Image placement skills.</TD></TR></TABLE>
Don't post anymore
It sounds like the stud was cross-threaded at some point. If the whole stud is coming out with the nut, it's already loose and should be replaced anyway. So, pull the whole stud out and pick up a replacement from either your local hardware store or from Honda. Pick up a replacement nut as long as you're there - the threads on the inside of the nut might be damaged too. An alternative would be just cut the stud off.
When you reinstall the new stud, use a dab of Locktite on the threads that sink into the head. Of course, *don't* get any on the threads that the nut will touch.
Old Apr 12, 2006 | 04:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Either the valve cover stud is broken (common problem) or the nut is just getting stuck. Either way you should be able to get the valve cover off with the stud still in there. If it's not broken and instead unscrews from the head itself, then just pull the valve cover off, grab the bottom of the stud w/ a wrench or pliers (there are 10mm flats below the valve cover) and remove the nut on top.
It's a special double-ended stud, you'll have to get one from a dealer or junk yard or friend who has tons of Honda bolts laying around. You can't get one from a hardware or auto parts store.
j.RUNek9
Feb 14, 2008 03:28 PM
tigueremalo
Oct 9, 2007 02:39 PM
hondajav06
Mar 20, 2007 06:36 AM
E46Kid
Sep 17, 2006 07:43 PM
2muchGT
Oct 9, 2003 02:07 PM
