Oil Flush
Old Apr 12, 2006 | 11:34 AM
Jakester9500's Avatar
Default Oil Flush
I have been running synthetic blend in my car forever now, but I was considering getting some synthetic because I hear good things. I mentioned this yo my friend and he said that I would have to flush the oil out completely before making the change. Is this something I can do in my backyard, or will I pretty much have to take it somewhere to get a flush?
Old Apr 12, 2006 | 11:52 AM
Padawan's Avatar
Darth ModerVader
Default Re: Oil Flush (Jakester9500)
There is no need to "flush" the oil. Commercially available fully synthetic oils are perfectly compatible with blends and conventional oils.
Old Apr 12, 2006 | 11:58 AM
So anything then. Sorry if I sound retarded, I am still trying to learn some things. But if I wanted something more along the lines of Royal Purple or Greddy's new synthetic, I could just put that in with oil residue? That would be great.
Old Apr 12, 2006 | 12:51 PM
Padawan's Avatar
Darth ModerVader
Default Re: (Jakester9500)
http://www.royalpurple.com/techa/faqsa.html#mo2
Old Apr 13, 2006 | 08:04 AM
That link was very helpful. Thanks man.
Old Apr 13, 2006 | 02:06 PM
postman's Avatar
typically only bad to go from synthetic to regular, always upgrade never downgrade
Old Apr 13, 2006 | 02:14 PM
non-VTEC's Avatar
Default Re: (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">typically only bad to go from synthetic to regular, always upgrade never downgrade</TD></TR></TABLE>
that is incorrect........you can switch back and fourth with no problems........
Old Apr 13, 2006 | 03:59 PM
murtnabila's Avatar
Default Re: (non-VTEC)
the only thing you have to worry about it going from conventional to synthetic if your motor has a lot of miles. Your problems will be w/ leaks cause of the seals which had got the oil build up on it and dried, then w/ the synthetic the gunk begins to remove and you get leaks.
Trk2112
Jun 19, 2010 03:48 PM
Notorious_T
Apr 28, 2009 12:00 PM
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
ironballz
May 13, 2004 02:38 PM
blkbeast
May 28, 2003 10:48 PM
