EG DX motor into EF DX...
Old Apr 12, 2006 | 09:58 AM
thenick's Avatar
Default EG DX motor into EF DX...
Hey guys, I got a good deal on a longblock with low miles and great running condition. My goal was to do an engine swap with a bit more pep, MPFI, and with an SI tranny.
My question is though, do I necessarily have to convert to OBDI to use this motor? Theoretically, can't I just install an A6 distributor and A6 injectors onto the motor and run it off of a PM6?
Also are the sensors on the block different at all from an EF or is it all plug and play? I really don't want to convert to OBDI and I'm just trying to get a healthier motor in my car. Thanks in advanced!
Old Apr 12, 2006 | 10:25 AM
thenick's Avatar
Default Re: EG DX motor into EF DX... (thenick)
Also, I got a 91 SI trans laying around. What clutch setup do I use, the one off of my current 91 DX or the the clutch setup from the EG DX motor (D15B7)
Old Apr 12, 2006 | 10:26 AM
onepoint6i's Avatar
yep just keep it obd0 no need to convert anything...
you use the clutch for that tranny...
Old Apr 12, 2006 | 10:29 AM
thenick's Avatar
Default Re: EG DX motor into EF DX... (onepoint6i)
So that's all that's needed -- injectors, dizzy, and ECU? No knock sensors or any of that jazz have to be switched from an EF motor?
Thanks for the help
Old Apr 12, 2006 | 10:31 AM
onepoint6i's Avatar
yeah its pretty straight forward...you possibly may have to change the fan switch plug but thats it, that i could think of.....make sure you use the a6 mani for an easier install..
Old Apr 12, 2006 | 10:42 AM
thenick's Avatar
Thanks alot for your help man ... one final question -- if I don't have access to an A6 intake manifold what would be needed to make the D15B7 work. I also have a D16Z6 manifold laying around if that would make the install easier....
dr_latino999
Aug 18, 2005 06:20 AM
eggizle
Oct 29, 2004 10:48 PM
eggizle
Oct 29, 2004 10:12 PM
