does ac and ps steal hp?... how much if so
Old Apr 12, 2006 | 09:52 AM
BigECivic's Avatar
Default does ac and ps steal hp?... how much if so
just wondering if ac and power steering steals hp from the engine and how much
Old Apr 12, 2006 | 12:16 PM
Jakester9500's Avatar
Well it steals some power, anything that is belt driven steals hp. How much, I couldn't tell you that.
Old Apr 12, 2006 | 06:54 PM
dwolsten's Avatar
Default Re: does ac and ps steal hp?... how much if so (BigECivic)
Short answer: YES
Longer answer:
A/C: probably 10-20%, depending on the engine. Of course, there's a simple way to avoid this power loss: turn off the A/C!!! If the A/C is off, the only power loss is from spinning the A/C pulley, but this is probably negligible as long as your A/C compressor's in good shape.
P/S: usually around 3-5%, when you're not even steering. This is a pretty substantial loss for something that is only useful at low speeds, and that's why car companies are (too slowly IMO) moving to electric power steering, since that only consumes power when you're actually turning the wheels, and usually deactivates altogether at higher speeds. The new high-economy hybrid cars like the Insight, Hybrid Civic, and Prius all have EPS systems because fuel economy is such a concern for them.
Old Apr 13, 2006 | 09:46 AM
DjChuckey's Avatar
is there a way to intstall EPS?? because ti really sux not having P/S when im tryin to turn the wheel at a stop...its a good work out tho :-P ..
Old Apr 13, 2006 | 12:27 PM
archmage's Avatar
Default Re: (DjChuckey)
I think there's a method using pressure allowing manual steering with ease...relatively...
someone link that ? I decided against it...but I may try it out later
Johnoolo
Dec 29, 2018 03:11 PM
maal15
Feb 4, 2010 08:48 PM
sickofitall1113
May 17, 2005 08:02 PM
Hatch It
May 14, 2004 08:56 AM
SPOOLINVTEC
Nov 14, 2003 07:50 AM
