how hard is it to put in new axles?
Old Apr 12, 2006 | 09:51 AM
BigECivic's Avatar
Default how hard is it to put in new axles?
95 civic dx d15b7 manual
i have helped a guy put axles in a geo storm before, and it was almost impossible to get the old ones out from what i remember, it has been a long time
Old Apr 12, 2006 | 10:02 AM
snatch's Avatar
Default Re: how hard is it to put in new axles? (BigECivic)
They're not too bad, hardest part is probably getting them out of the hub. Just takes a lot of hammering. You have to separate the lower balljoint, knock the axle of the hub, then pull it out of the tranny.
Really pretty easy.
Old Apr 12, 2006 | 10:05 AM
BigECivic's Avatar
thanks for the info
Old Apr 12, 2006 | 12:15 PM
BMaDOHC's Avatar
Default Re: (BigECivic)
a word of advice, pop out the axle with a pry bar before removing from ball joint or hub. sometimes when you start moving the axle around in different directions without popping it out first the c clip gets jammed and doesn't want to come out.
Old Apr 12, 2006 | 01:00 PM
Danronian's Avatar
Before you do anything get that axle nut off. That'll be the biggest hurdle. You'll need the motor to hold it.
Old Apr 12, 2006 | 04:42 PM
BigECivic's Avatar
thanks, do the new ones just slide in, will i need to hammer them in, how do i know when i have them in all the way
Old Apr 12, 2006 | 07:34 PM
bobbyg crxh22's Avatar
when putting back in put like a hose clamp around the c-pin and then hammer in a little bit then take the clamp off then put it in the rest of the way...trust me i didn't do that on the first time i did that and i didn't get it in and messed it all up....and had to get a new c pin....and yea wasn't cool....trust me it works alot better when you do that
Old Apr 12, 2006 | 08:12 PM
HamiltonRex's Avatar
Default Re: (CRX DX 2 LS BobbyG)
hardest part IMO - getting the lower balljoin apart without destroying it!
Just crack the 32mm axle nuts loose.. remove
Jack up car, remove wheel.
Loose lower balljoint.. remove, various methods.
If the axle is stuck in the hub, may require some elbow grease.. IE - BFH.
use a small prybar and pop the axles out of the tranny..
Remove axles..
Install reverse...
Toruqe axle nuts to 130ft/lbs w/new nuts, then Lock them.
Use new cotter pin in balljoint
Well under car, do oil change and tranny fluid change.
Old Apr 12, 2006 | 09:55 PM
Danronian's Avatar
On all the axle installs i've done, I've NEVER had a problem getting them in. ONce i forgot to put the c-clip on since the reman didnt come with it, but i saw it wasnt staying, so that was an easy fix too.
Old Apr 13, 2006 | 02:25 PM
Wayne_Curr's Avatar
Default Re: (Danronian)
Hardest thing i've encountered is getting the driverside axle off the intermediate shaft...no room to pry. Just put a pry bar up next to it and hammer with all you've got and that ******'ll pop off eventually.
EDIT-I see its a civic, not sure if those have intermediate shafts.
Old Apr 13, 2006 | 02:50 PM
Walterronny's Avatar
https://honda-tech.com/zerothread?id=1135275
what part is the lower balljoin?
Old Apr 13, 2006 | 05:30 PM
Wayne_Curr's Avatar
Default Re: (Walterronny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Walterronny &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1135275
None of that. Those are the Axle Assemblies. The Lower ball joint connects to the LCA.
Old Apr 13, 2006 | 06:44 PM
bukfuddie's Avatar
USE BIG AIR GUN !
Old Apr 13, 2006 | 07:24 PM
.Ry's Avatar
.Ry
lol if you dont know what a ball joint is, I highly doubt you should be doing this.
Old Apr 13, 2006 | 08:55 PM
Default Re: (Wayne_Curr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wayne_Curr &raquo;</TD></TR><TR><TD CLASS="quote">Hardest thing i've encountered is getting the driverside axle off the intermediate shaft...no room to pry. Just put a pry bar up next to it and hammer with all you've got and that ******'ll pop off eventually.
EDIT-I see its a civic, not sure if those have intermediate shafts.</TD></TR></TABLE>
Im not a D series expert.. But heres my take.
D series.. dont use intermediate shafts.. so no equal lenght axles. B series use shafts.
Old Apr 14, 2006 | 02:24 AM
xd69's Avatar
Default Re: (HamiltonRex)
"******" couldnt have said it better.....
Old Apr 14, 2006 | 02:39 AM
Default Re: (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">lol if you dont know what a ball joint is, I highly doubt you should be doing this.</TD></TR></TABLE>
maybe i know this part with other name.. (in spanish probably)
ugandaHonda97
Dec 15, 2010 12:59 PM
88crxhfb16
Aug 8, 2005 05:09 AM
93egsi
14
Jul 9, 2004 10:10 AM
Ladysman_civic
Sep 4, 2003 02:13 PM
projecthybrid04
Sep 26, 2002 06:38 AM
