lsd and noises
Old Apr 12, 2006 | 08:08 AM
vtecb20coupe's Avatar
B A N N E D
Default lsd and noises
this is a question for any honda owners with an lsd equipped tranny. whether it be oem/jdm, aftermarket, open or helical type.
upon initial break-in or after a few hundred miles of driving, did it make any noises while turning? any clunking noises? most would think it would be the cv axles but it's not a clicking.
i've got a friend with an issue and we are trying to figure out if its normal and to get used to it. or, if there is indeed something wrong with his lsd. any helpful info is appreciated.
Old Apr 12, 2006 | 08:24 AM
Golden Eagle's Avatar
Default Re: lsd and noises (vtecb20coupe)
it all depends on what lsd you have
Old Apr 12, 2006 | 08:36 AM
B A N N E D
i personally have no idea. he bought the swap from a friend.
also, we put the car on jackstands in the air to try to reproduce the problem. it would not make the noise unless we put the car in gear and popped the clutch. when this was done, the noise was very minimal.
Old Apr 12, 2006 | 12:02 PM
Default Re: lsd and noises (Golden Eagle)
what trans oil is he using
Old Apr 12, 2006 | 03:32 PM
B A N N E D
honda mtf
also, while turning, it only makes the noise while the clutch is engaged. if you cruise the corner in neutral, you hear nothing. i'm stumped.
Old Apr 12, 2006 | 05:42 PM
Dogginator's Avatar
Daisy... Daisy...
If the car is in the air, the motor is not running, and the transmission is in gear, can you turn the front wheels by hand? If not, you have a clutch pack LSD. If so, you have a helical LSD, which should make no noise. Clutch pack LSDs often require special transmission fluid.
Old Apr 13, 2006 | 07:45 AM
B A N N E D
Default Re: lsd and noises (Dogginator)
thanks for the info. i'll try jacking it back up in the air to see.
Old Apr 13, 2006 | 08:01 AM
B A N N E D
also, if it is a clutch type, what type/weight gear oil should i try out?
Old Apr 13, 2006 | 08:17 AM
Dogginator's Avatar
Daisy... Daisy...
It helps to know who made the LSD unit if it is a clutch type. If I recall correctly, Kaaz has a special fluid for their units. Someone on here has to have better knowledge than me regarding this.
Old Apr 13, 2006 | 08:37 AM
ans so you do know some lsd just make noise nothing you can do but you do need lsd trans fluid that will held it not to be so loud
Old Apr 13, 2006 | 10:08 AM
B A N N E D
well, i picked up some redline mtl and a bottle of gm synchromesh with the friction modifier today. hopefully this will quiet it down.
Old Apr 13, 2006 | 02:37 PM
unless it is redline lsd oil it will do nothing for you and you will destroy your lsd
Old Apr 14, 2006 | 06:14 AM
B A N N E D
i know that redline makes an oil with a friction modifier in it, if this is what you mean. but i was unable to find it.
Old Apr 14, 2006 | 08:21 AM
if it don't say lsd oil on it its not right it will say for lsd trans on it you can get some at any auto parts store any brand will work
Old Apr 14, 2006 | 08:11 PM
rmcdaniels's Avatar
I have a Quaife that I use with Honda MTF, it's never made any kind of noise.
Old Apr 17, 2006 | 07:52 AM
Default Re: lsd and noises (rmcdaniels)
your using the wrong oil call quaife they will tell you.
Old Apr 17, 2006 | 07:58 AM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote">your using the wrong oil call quaife they will tell you.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quaife ATB FAQ &raquo;</TD></TR><TR><TD CLASS="quote">What sort of gear lube should I use ?
For QUAIFE ATB Differentials:
When running a QUAIFE ATB Differential in a standard transaxle gearbox, we recommend that you use whatever your vehicle's manufacturer recommends. The QUAIFE ATB Differential does not require any special lubricants. .</TD></TR></TABLE>
starcraft232
Transmission & Drivetrain
Mar 11, 2009 11:57 AM
ITR_HO
Feb 9, 2007 03:02 PM
aeolus
May 17, 2004 02:12 PM
red civic standard
10
Oct 1, 2003 11:20 AM
