Ls Vtec High compression can't feel Vtec is this true? Help look!
Old Apr 12, 2006 | 05:54 AM
Vtecme92's Avatar
Default Ls Vtec High compression can't feel Vtec is this true? Help look!
Ok here is my situation; I was running a stock LS block on a stock gsr head with a p72 ECU. I felt the Vtec kicked in around 4200 rpms, but now I have rebuilt the block and head with pr3 pistons and type r cams alot more power but I can't feel the vtec anymore; I was told by a buddy because I am high compression like a turbo car I can't feel the vtec but everything is wired up is this true with high compression? any inputs or personal experience let me know!
Old Apr 12, 2006 | 05:57 AM
Rajin's Avatar
Default Re: Ls Vtec High compression can't feel Vtec is this true? Help look! (Vtecme92)
High Compression and turbo...that doesn't happen.
You can't feel VTEC...hmmm you do know that the VTEC cars are generally higher compression don't you?
Old Apr 12, 2006 | 06:02 AM
Vtecme92's Avatar
Default Re: Ls Vtec High compression can't feel Vtec is this true? Help look! (Rajin)
What I meant was a turbo car has a lower compression but my freind told me my car is a like a turbo/ supercharge car now cause it pulls hard but I can't feel the vtec just like turbo or supercharge cars...my compression right now is about 11:9 according to C-speed calculating compression... I know gsr and itr have a higher compression but when I had my orginal ls vtec build my compressin was about 10:5 now i am 11:9
Old Apr 12, 2006 | 06:12 AM
Rajin's Avatar
Break your posts into sentences.
I've been in few LS/Vs that you can't tell the changover to VTEC in.
Old Apr 12, 2006 | 10:55 AM
Yoinked's Avatar
Can you at least hear it? I've never heard or seen this before, I've been in a B20VTEC I could hear and feel the crossover. Never been in a LSVTEC though...
Old Apr 12, 2006 | 10:58 AM
CleanLikeJdm's Avatar
Hype-R Stalker
You know, Usually when you can't feel the crossover point, that's a Good thing.
Old Apr 12, 2006 | 10:59 AM
Yoinked's Avatar
Default Re: Ls Vtec High compression can't feel Vtec is this true? Help look! (FlatBlackTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlatBlackTeg &raquo;</TD></TR><TR><TD CLASS="quote">You know, Usually when you can't feel the crossover point, that's a Good thing.</TD></TR></TABLE>
Hahahaha for sure that's a good thing.
Old Apr 12, 2006 | 12:01 PM
Rajin's Avatar
Default Re: Ls Vtec High compression can't feel Vtec is this true? Help look! (negtegra.)
Yeah, loud obnoxious changeovers aren't great.
Old Apr 12, 2006 | 12:13 PM
milano2kdc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecme92 &raquo;</TD></TR><TR><TD CLASS="quote">Ok here is my situation; I was running a stock LS block on a stock gsr head with a p72 ECU. I felt the Vtec kicked in around 4200 rpms, but now I have rebuilt the block and head with pr3 pistons and type r cams alot more power but I can't feel the vtec anymore; I was told by a buddy because I am high compression like a turbo car I can't feel the vtec but everything is wired up is this true with high compression? any inputs or personal experience let me know!</TD></TR></TABLE>
your problem is tuning, your p72 will not do the job. It happened to me, I have a gsr motor with pr3 pistons and type-R cams. My stock ecu made it slower, but I got a P73 ecu and it pulls great now.
Old Apr 12, 2006 | 12:44 PM
b00sted4dr's Avatar
Default Re: Ls Vtec High compression can't feel Vtec is this true? Help look! (milano2kdc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milano2kdc2 &raquo;</TD></TR><TR><TD CLASS="quote">your problem is tuning, your p72 will not do the job. It happened to me, I have a gsr motor with pr3 pistons and type-R cams. My stock ecu made it slower, but I got a P73 ecu and it pulls great now. </TD></TR></TABLE>
he has the answer. You need to tune it.
Old Apr 13, 2006 | 05:08 PM
Vtecme92's Avatar
Default Re: Ls Vtec High compression can't feel Vtec is this true? Help look! (b00sted4dr)
I will get the car tune in about 2 weeks
Old Apr 14, 2006 | 06:00 AM
PY TYPE R 483's Avatar
I can still feel/ hear my crossover point. My car has stock compression, and is supercharged.
Old Apr 14, 2006 | 07:16 AM
rockNrollteg's Avatar
dropping in bigger cams and pistons, you need to adjust a plethora of things.. ie: fuel curves, valve lash, make sure your timing is on point and a/f mixture. my suggestion, get a hondata unit and get that sucker tuned. also, did you bother to change the water pump and oil pump along with the belt?
the_big_dl86
10
Nov 26, 2007 02:45 PM
Cractos
Mar 18, 2004 03:45 PM
tcb18c5crx
Jan 15, 2004 01:43 PM
98 Ek LsVtec
Feb 7, 2002 09:25 PM
