Help: Swap a first gen jdm b16a to a 1989 crx si
Old Apr 12, 2006 | 12:23 AM
ef8sleepr's Avatar
Default Help: Swap a first gen jdm b16a to a 1989 crx si
help. i need to know what do i need to swap the b16a engine in my car. do i need b series motor mounts since the b16a was on a EF? and it came with the pr3 ecu. how do i wire the vtec and stuff? and how about the shift linkage? would my shift linkage work on the motor as well??
Old Apr 12, 2006 | 02:11 AM
crxnj's Avatar
Default Re: Help: Swap a first gen jdm b16a to a 1989 crx si (ef8sleepr)
B-series engine mount kit into the 88-91 chassis..
Pre-made shiftlinkage for the swap or cut and reweld an integra unit..
Make a pretty big size dent on the inner fender for alternator clearence..
Most mount kits require you to use a rear mount bracket from a 90-93 integra..
Add 4 wires for vtec activation and pin them into the ecu clips..knock sensor,2nd o2 sensor,Vtec oil pressure,and Vtec solenoid..
Remove the dust rings from inside the crx hubs to prevent axle binding..
For axles you can use any b-series on the passenger side ,,but on driver side you have to match the axle to halfshaft..And with the 1g b16 halfshaft you have to custom make an axle using 87-89 axle and 90-93 axle...Or simply convert the halfshaft to 90-93 integra and just use 90-93 integra to simplify your life..
Here is a vtec wiring schematic to help you out..Theres more **** ,just search for that..
integrawow
Jun 13, 2007 09:34 PM
jake1511
Jun 12, 2005 08:33 PM
swappedb16teg
Mar 20, 2005 10:16 PM
honda06si
Aug 7, 2004 02:55 AM
I3ackfire
Mar 17, 2004 01:52 PM
