MY DA WONT START HELP PLEASE!!!!!
Old Apr 11, 2006 | 11:31 PM
94_vteckiller's Avatar
Default MY DA WONT START HELP PLEASE!!!!!
I just got the motor in the timing is good and lined up its getting spark and fuel what the hell is it i am also 100% sure it has fuel please help my por gsr
Old Apr 11, 2006 | 11:37 PM
ekzrated's Avatar
Default Re: MY DA WONT START HELP PLEASE!!!!! (94_vteckiller)
You need to be a little more descriptive. Is it cranking? Is it getting enough fuel? how does it behave? etc. -ekzrated
Old Apr 12, 2006 | 01:10 AM
it is cranking its getting fuel it just cranking but not staring
Old Apr 12, 2006 | 09:06 AM
RaceCarRyne's Avatar
Default Re: (94_vteckiller)
check ur main relay.. they sometimes go bad.. if that doesnt work check all grounds.. fuses relays ect.. good luck
Old Apr 12, 2006 | 09:15 AM
projectTeG's Avatar
Default Re: (DC2jdmIntegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2jdmIntegra &raquo;</TD></TR><TR><TD CLASS="quote">check ur main relay.. they sometimes go bad.. if that doesnt work check all grounds.. fuses relays ect.. good luck</TD></TR></TABLE>
also make sure your timings right, i had that problem last night...i was horribly tired and i just wanted to get it running....so yea...have you ever seen a header glow red?...lol
you might just need to force start it.
Old Apr 12, 2006 | 10:48 AM
Yeah my timing is perfect i know for a fact it is
Old Apr 12, 2006 | 01:16 PM
psychotic_z's Avatar
Random thought...
You swapped in a B18C1, I'm assuming... and is your DA a 90-91 or 92-93?
Your 90-91 injectors will be peak and hold type - your B18C1 injectors will be saturated type. If you didn't swap the injectors or eliminate your resistor box from your injector wiring than you'll be stuck without fuel. Also... got any ECU codes?
Otherwise, if you want more help, than you'll need to give more information than "waah, my car won't start... The timing is perfect, I PROMISE! It's getting spark and fuel!"
Old Apr 12, 2006 | 03:10 PM
g2xsi's Avatar
check your distributor..
Old Apr 12, 2006 | 05:19 PM
Default Re: MY DA WONT START HELP PLEASE!!!!! (g2xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2xsi &raquo;</TD></TR><TR><TD CLASS="quote">check your distributor..</TD></TR></TABLE>
Not a bad idea. But, if you're getting spark, like you're so sure you are, make sure the spark is going to the right place at the right time. Meaning, check your plug wire order. Refer to your shop manual for the order - I can't remember off the top of my head.
Luke 91 ef
Jan 24, 2013 10:40 AM
stiffinEK
Dec 1, 2007 05:02 AM
turbocivic0618
Nov 24, 2005 08:20 AM
bigbacon2
Sep 17, 2005 03:41 PM
CXHatchback
Nov 23, 2004 11:32 AM
