PW0 on CR-VTec
Old Apr 11, 2006 | 05:54 PM
jdmEF8racer's Avatar
Default PW0 on CR-VTec
i jus got a b20 for my crx. i blew my last motor (b16) and i have a PW0 ecu from the last motor...would this ecu work good on the motor or should i jus get a pr4 from a ls?
Old Apr 12, 2006 | 11:14 AM
EFSiR's Avatar
Default Re: PW0 on CR-VTec (jdmEF8racer)
I'd settle for the LS but that's not gonna cut it any hell with the fuel...
Old Apr 12, 2006 | 03:33 PM
jacoop86's Avatar
Default Re: PW0 on CR-VTec (EFSiR)
i'd say either use your pw0 ecu, chipped and tunned, or get a obd1 conversion and an obd1 gsr ecu, then again chip, and tune it. if untunned, either ecu is going to make your engine run lean. a good site to get started with ecu tunning/chipping is http://www.pgmfi.org/
using a pr4 ecu will not let vtec engage unless you have some crappy switch or something like that.
Old Apr 12, 2006 | 03:34 PM
si0385.'s Avatar
it will run with it but i wouldint beat on it like that... i would get it chiped and have someone burn you a chip with different fuel maps in it
Old Apr 12, 2006 | 04:21 PM
KrenzyRyan's Avatar
Default Re: (si0385.)
How did you blow your b16?
98bucket
12
Oct 24, 2010 04:13 PM
Stray
15
Jul 28, 2007 02:34 PM
mawkiemarc
22
Feb 28, 2006 12:21 AM
No
Feb 1, 2005 06:33 AM
LSCivic
Sep 16, 2001 10:54 PM
