Fabbing an exhaust
Old Apr 11, 2006 | 05:06 PM
josh green's Avatar
Default Fabbing an exhaust
I have a k20/eg and I have 2 3" exhausts, 1 is mandrel bent and the other is crush bent, I know the crush bent is garbage. I am looking to make a 3" exhaust that is quiet. At the moment my car is N/A and I am in the works of build a turbo motor, but at the moment the exhaust is driving me crazy. I know most of you guys make much more skill oriented parts but w/e. I need some suggestions, resonator+ muffler, or a certain muffler thats quiet enough? I have a flow master 3" and I took that off the 1st day it was on, it sounded like a tin can and like someone was strangling a goat when I got on it. Thanks for the help.
Old Apr 11, 2006 | 05:45 PM
Mugencrxsir1's Avatar
Default Re: Fabbing an exhaust (josh green)
Yeah your first mistake was the flow master, domestic mufflers are usually junk for imports. Now get a vibrant resonator, with a apexi sport muffler from ebay.
Old Apr 11, 2006 | 06:09 PM
dfoxengr's Avatar
Default Re: Fabbing an exhaust (Mugencrxsir1)
kteller kit and magnaflow muffler +resonator.
loving mine.
Old Apr 11, 2006 | 07:36 PM
kungfuSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah your first mistake was the flow master, domestic mufflers are usually junk for imports</TD></TR></TABLE>
That's a somewhat unreasonable comment.
I use a magnaflow 3" on my 2.0L N/A Civic and it's great. It's extremely quiet, and the sound is beautiful not to mention that it's been on the car for nearly 3 years without any hint of rust or anything.
I find most of the japanese mufflers to be obnoxiously loud, especially when you are talking about anything in the 3" range.
Old Apr 12, 2006 | 02:07 AM
Jamez's Avatar
Default Re: Fabbing an exhaust (kungfuSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kungfuSiR &raquo;</TD></TR><TR><TD CLASS="quote">That's a somewhat unreasonable comment.
I wouldn't say so. Magnaflow may be the exception but a lot a stuff made for domestics is pure junk. Some of it is useless at reducing noise (glass-packs) others just don't reduce it by much (Flowmaster).
I would like to see manufacturers design a line of affordable performance non-straight through mufflers aimed at imports. Something that's a good balance of sound and flow. Not something that sacrifices flow and still sounds like ****.
On a side note for anyone that cares, a 6"X18" muffler is a real tight fit for a resonator on a Civic EG. I choose it because I was uncertain if a 4"x22" would be too long. I finally had a sunny day off to work on my exhaust yesterday and it turns out there's plenty room for a 22" long resonator on an EG. A 6"X18" model will fit only if you remove the heat shields and hammer some gussets flat plus ground clearance is compromised. Cliffs ; for max sound reduction go with a 4"X22" resonator, not a 6"X18".
Headlessmunky
Nov 29, 2008 05:35 PM
adam_mcd
Jan 11, 2006 06:34 PM
zumiez007
May 16, 2005 09:24 AM
variable_x
Jul 25, 2002 11:53 PM
