My Car needs more Garage room, buy my stuff! *pictures* 56k...not really...
All prices are negotiable, please make an offer if you want it for less, that said I have not checked around for what any of these things are going for, just pricing them off what I think they're worth. EVERYTHING must go.
I reserve the right to sell these parts locally untill I've received money from you. These are on a local board too, so first come first served.
e-mail works best to ben_inglis@hotmail.com
I'm going to the post office tomorrow to check on flat rate shipping prices, so I'll add shipping info tomorrow night. All that said, here comes the stuff....
D series AC Compressor, and bracket: $30 for both Compressor worked when i took it off the motor 4 years ago or so. bracket and pully are in good condition.
2 AC Fans, off stock condensors, good and working condition: $10 each
Stock Radiator fan $10
Red/Clear tail lights, generic, some guy sold me to them as JDM, they aren't, they were once clears and he added red, doesn't look to bad, just decided to go stock. $20 for the set
one of the tails is missing a side mounting bolt. I can send you pictures of exactly what I'm talking about, but it mounts fine and no problems with leaking.
Chrystal clear corner markers, good condition, they might leak a little $10
1 clear (I think it's a right) corner marker, not chrystal, but in good shape if you need one $10
You won't get tired after a long march with these projector head lights, one has a crack, generic $50
cracked one leaks, but doesn't fog much.
Used clutches, one is an exedy, the other is an autozone special. the exedy is in better shape, tried to show wear in the pictures.
Better one $45
worse one $25
drivers side DX brake caliper, in good working condition, line attatched to it is cut, but i will include a good one: $15
brake line $5
2 honda centercaps, they fit 14 inch rims that came off 95 honda civic EX's $5 for the pair
cruisecontrol off a 95 honda civic EX, worked when I pulled the motor
injectors out of a 95 honda civic EX $8
left strut assymbly $15
13/16 master cylender off 92 honda civic DX, good condition, wored when pulled to do GSR Swap
Moter mounts, one off of a D15Z6 motor, driver side. Other one I have no idea. $5 each
Rear Motor mount off D series motor $10
Power stearing mount off D series motor $10
2 stock shifters $5 each
"spoon replica mirrors" bought them cheap off ebay, mounted one, didn't like the way it looked so I never mounted the second one. $15
Top timing belt cover for D series motor $10
Freebies if you spend $20 or more (these are basically a joke, didn't think anyone would buy them...)
12 inch neon black light, runs off cig-lighter
Harbor freight plastic wrench rack for open ended wrenches
Better one $45
worse one $25
brake line $5
chromedoutteg
Oct 17, 2006 08:34 AM
KornyCivic
Apr 18, 2006 10:08 PM
advan7
May 14, 2002 08:27 PM
