Okay Accord guys i need some help, car start but die right away......
Old Apr 11, 2006 | 12:10 PM
sPaRk'iT's Avatar
Default Okay Accord guys i need some help, car start but die right away......
My girlfriend nephew 95 accord, when you turn the key to ON the car start but once it starts then the car die, it doesnt seem like a starter problem at all and if you hold the key on "START" the engine will stay on running but once i let go the key the car die again. I have a feeling that the clutch is not engaging or its out because he said that the clutch was slipping hard before. I check everyhing else and it seems fine maybe a ignition problem? has anyone encounter this problem before??? Any ideas???
Modified by sPaRk'iT at 10:00 PM 4/11/2006
Old Apr 11, 2006 | 12:16 PM
Ross 2.0's Avatar
In a Junkyard near you.
Replace the electrical side of the ignition switch 100% garuntee.
Old Apr 11, 2006 | 12:24 PM
hondadude's Avatar
Default Re: Okay Accord guys i need some help, car start but die right away...... (sPaRk'iT)
When you are replacing the electrical part of the ignition switch; be very careful of the SRS ribbon cable. It is very easy to damage it.
Old Apr 11, 2006 | 12:59 PM
sPaRk'iT's Avatar
Default Re: (MooGoCow3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">Replace the electrical side of the ignition switch 100% garuntee.</TD></TR></TABLE>
What do you mean the elecrical side?? replace the whole ignition switch???? have any idea how much it cost??? Someone just told me that its the main relay? but not sure...
Old Apr 11, 2006 | 01:06 PM
Ross 2.0's Avatar
I replied to your PM and i'll bet too that it isn't the main relay if it is caused by you playing with the key.
maxrealtor
Mar 3, 2011 07:55 AM
Goldest
Dec 15, 2010 03:07 AM
heydave23
Aug 18, 2007 07:45 PM
JimKW
Sep 20, 2005 10:37 AM
notoriousB
Jan 11, 2005 03:28 PM
