I need help with the ABS Light.
Hi, I have a honda accord '93 it has about 175,000 miles and ABS ligh cames on after right after I star driving but sometimes it doesn't. What it happen was that i changed the front and rear breaks, but i had some little problems with the rear break cylinder, in the process of replacing the pads I opened the bleeder duct and let the break fluid run a litle bit thinking that may help to move the cylinder in by pressure. I didn't know that you have to move it clockwise in order to put the new pads. any ways I finally figure it out. when I was driving I notice that when press the break pedal it goes all the way down and it has no pressure. so then I bleeded not one time but fourtimes already, but I still have this problem. However is not allways, sometimes it works perfectly..........ANY IDEAS. THANK YOU. ANY THING WILL HELP.
by the my car is a honda accord 1993 with 180 millas apox.
I pull out some cosdes they are as follow blinked four times then a pause then blinked eight times
does someone knows what that is?
jayp4757
Apr 26, 2006 12:40 PM
