Got a question on b16 in ef. Dizzy wires from ecu?
Does it matter which one goes to what? I know there is two and where at on the ecu. Everything else is ran and good. I just am curious before I solder connections that I have it correctly.
So does it matter which wire goes to the other.
I know which two wires to connect to, just not which order.
TYIA
TYIA
Do you know which one goes to which. Out of all the swap material I have found in the last few weeks it just says to hook em up it didn't really say "example" from ecu B5 to blue/white wire,, etc" So I am not sure, guess I will have to do some more searching.
Thanks
Here is the main swap info that I have used:
https://honda-tech.com/zerothread?id=1193782
And I know this is dpfi to mpfi but the C1 and C2 plugs on harness would they go to the different color wires. I will have to look but I think the colors are right. I am just trying to hash this out by typing. Helps me think clearer. Maybe.
http://stereophonik.com/gutter....html
Thanks
I am having problems with my dizzy two I have 5 of 7 wires run for the dizzy there are two blue wires that I do not were they go? blu/yel and blu????
prelude182
Mar 14, 2011 09:29 AM
janz3n
Apr 28, 2006 07:06 AM
AGPSuperstar
May 7, 2003 03:20 PM
