B18A/B engine and lots of 90 CRX Si and 91T MR2 Parts
Board Name: Mr.Saturn
Means of Contact: e-mail - mrsaturn7085@comcast.net
Prices are all best offer unless noted, I really just need to clean the garage and much will be thrown out if not sold!
Parts from 1990 Honda CRX Si - car garaged 6 years, most parts mint
- Autopower 4-pt bolt-in rollbar with removable crossbar & harness bar $350
- JDM rear seat, complete with brackets and trunk carpet $350 OBO
- JDM trunk cover, fits with JDM rear seat only!
- 100% perfect black Si door panels, I've never seen a better set
- Stock Si complete rear sway bar/brackets
- Generic brand rear strut bar
- Stock F/R shocks and struts including front forks
- Stock upper front control arm mounts
- Stock Si front lip
- Clear bumper lights, aftermarket, good quality
- Stock wiper cowl
- Stock exhaust manifold, O2 sensor, and heat shield
- Stock throttle and clutch cables
- Stock alternator
- Stock A/C compressor, wiring, and fan
- Stock floor mats (driver's side 8/10, passenger's side 9.9/10)
- Stock side rear cargo pockets, fits with JDM rear seat or OEM cargo box
- Stock rear speaker mounts and cloth/plastic cover plates
- Black interior trim including: A-pillars, hatch trim w/3rd brake light (2 pieces), dome light panel, trunk center panel w/reverse light covers, mint headliner, rear side window surrounds, and door sills.
- Heater system: heater control, heater, blower, coolant valve and pipes SOLD
- Spare tire and toolkit
Other Honda Parts
- B18A block, needs oil pan
- Low milage B18B head, needs cams
- B18A/B intake manifold
- Spare B18A/B water and oil pumps (included with block if requested)
- B18A/B P/S pump and idler
- HF exhaust manifold with O2 sensor/heatshield (great for turbo adaptor)
Other parts
- 1 Audiobahn 1205Q 12" Sub
- Sparco 4-pt buckle harnesses (2 sets)
Parts from 1991 Toyota MR2 Turbo
- Stock downpipe/cat/cat stays/heatshields
- Stock intercooler/shroud/fan (harness cut)
- Stock IC to TB intake pipe
- Stock A/C compressor with A/C VSV
- Full EGR system
- Cruise Control motor/actuator/ECU
- Stock muffler in great shape
- Large heatshield over muffler
- Front trunk lining and metal support piping
Modified by Mr.Saturn at 3:15 AM 4/27/2006
- Stock wiper cowl
- Stock alternator
Other Honda Parts
Other parts
- Full EGR system
From: if you build it they will come, the bottom carolina, duh
i am interested in the cage, but gotta try and gather money, and are you willing to ship or is it pick-up only, you said its a bolt in does it come with all the necessary hardware.
i can give you 300 now but i dont think that that would cover shipping. but would you take 300. Do you know how much it would cost to ship. or a website for me to figure out.
I live in Beaufort, SC 29906
thanks
thanks
are you willing to sell the oil breather chamber with the hoses that go up to the pcv valve including the pcv valve??
icuracing.com
Nov 18, 2005 09:29 PM
