light / running light / corner light problem
Old Apr 10, 2006 | 05:29 PM
rcoolb2002's Avatar
Default light / running light / corner light problem
Done a bit of searching. I know the basis of the problem, but just wanted some opinions before i go hacking my wiring harness apart.
My corner lights (front) and both running lights (rear) are always on if the battery is connected. I was thinking possible relay problem so i replaced the ICU but that didnt fix the problem. They stay on with all the plugs on the steering column disconnected. I went through and unplugged each light bulb just incase one was grounding improperly.
As far as i can tell, the wiring harness under the dash is in good condition. There is no signs of tampering or stress on the harness. I bought the car with this problem.
Any ideas where the problem might be? The car is a 1990 DX hatch.
Old Apr 10, 2006 | 08:04 PM
yellowrexsi's Avatar
Default Re: light / running light / corner light problem (rcoolb2002)
Check all the light fixtures. Mine did it when the fixture had a dead ground. It was bad feeding power. Unsually they will be rusted.
Old Apr 17, 2006 | 05:21 PM
rcoolb2002's Avatar
Nothing really rusted. Everything honestly seems ok. I have stripped back the wiring harnesses all the way to firewall and see nothing wrong.
Old Apr 17, 2006 | 05:37 PM
mahatma's Avatar
Default Re: (rcoolb2002)
Wow that's crazy....so do you unhook the battery everytime you have to park it for a while?
Old Apr 18, 2006 | 10:32 PM
rcoolb2002's Avatar
Default Re: (mahatma)
I have a 100a breaker on it, and a master cutoff switch for the track. Battery is in the back of the car, but the problem existed before i ever moved the battery.
Kamikaze
Aug 4, 2006 07:35 PM
