How to remove a brake line routing bracket
Old Apr 10, 2006 | 05:07 PM
itsblue98's Avatar
Default How to remove a brake line routing bracket
I have some koni Yellows on my car. My friends and I installed them, we did not install the brake line routing bracket as we cannot remove it from the factory strut. Just want to know if anyone has done this or has any suggestions, also need to know if it will work with a koni strut.
Old Apr 10, 2006 | 05:14 PM
itsblue98's Avatar
Default Re: How to remove a brake line routing bracket (itsblue98)
Old Apr 10, 2006 | 05:15 PM
PrinceAli132's Avatar
Pic doesn't work.
I'm not sure on this but i don't think you can attach the bracket to the Koni's. I think we used some zipties on mine. Maybe some one can confirm this, cause im not 100% on this.
Ali
Edit - you can't upload a pic from your computer. You need to upload it. How-to
Posting Pictures - How to:
https://honda-tech.com/zerothre...25463
Resizing Images - using Powertoys for Windows XP
https://honda-tech.com/zerothread?id=890589
Old Apr 10, 2006 | 05:29 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Here is a link of a Koni install:
https://honda-tech.com/zerothread?id=1106020&page=1
On another site, one guy mentions to take the bracket from the stock struts by using a hammer. He also mentions that Konis don't come with the bracket, only Bilstein.
Notice in the pictures, the bracket includes the metal ring that goes around the strut.
Old Apr 10, 2006 | 05:53 PM
stumpyf4's Avatar
Big screwdriver (or chisel) and hammer. Stand the shock upright on a piece of wood, need helper to hold of the shock. Use the hammer against the end of the screwdriver and start tapping the bracket. It'll start to come loose after a few hard hits.
Old Apr 10, 2006 | 06:12 PM
projectTeG's Avatar
Default Re: How to remove a brake line routing bracket (stumpyf4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stumpyf4 &raquo;</TD></TR><TR><TD CLASS="quote">Big screwdriver (or chisel) and hammer. Stand the shock upright on a piece of wood, need helper to hold of the shock. Use the hammer against the end of the screwdriver and start tapping the bracket. It'll start to come loose after a few hard hits.</TD></TR></TABLE>
Old Apr 10, 2006 | 06:19 PM
JETSPD1477's Avatar
make sure you line up the bracket properly when putting it on the koni...
the bracket helps position the strut in the fork properly. without the bracket the strut sits too low in the fork LOL.
Old Apr 12, 2006 | 07:23 AM
itsblue98's Avatar
Thanks for all your help. WD40 and bout a 1/2 hour and a hammer did wonders, it's all installed and looks great.
fast95se
Nov 2, 2006 06:38 AM
Zion-I
Suspension & Brakes
Jan 19, 2006 06:32 PM
fireant
May 4, 2005 06:47 AM
tolnep
Jul 11, 2004 08:25 AM
CRXTSEE
Apr 10, 2003 07:19 AM
