a question about my accord
Old Apr 10, 2006 | 04:51 PM
mcrach's Avatar
Default a question about my accord
i have a 1989 honda accord lx. it turns over fine but when you take your foot off the gas pedle it dies. what could be wrong??
Old Apr 10, 2006 | 05:07 PM
YeuEmMaiMai's Avatar
Default Re: a question about my accord (mcrach)
fuel injected or carb'd?
Old Apr 10, 2006 | 05:20 PM
accord-pro's Avatar
Default Re: a question about my accord (YeuEmMaiMai)
lx is carburated....
have you checked the base idle setting?? ,, if ok..
also chk the pcv valve,, located behind the valve cover ,, get some pliers, squeeze the hose and see if that helps,,
........chk to make sure you are getting power at idle solenoid with key on.. located at back of carburator, you might have to remove the air cleaner assembly to get to it,,
If you get power , remove the 8mm screw,remove the solenoid CAREFUL not to lose the little o-ring ,, get some carb cleaner and spray some in there.. if you have compressd air blow in there as well.. put all together and retry it..make sure not to leave any vacc hoses disconnected.
try these things see if any helps..
Nicholas Mudd
Sep 29, 2015 07:55 PM
sherwo_od
Jul 3, 2010 11:15 PM
iderek
Nov 4, 2005 02:22 PM
warlock
Aug 24, 2005 10:50 AM
olds_442
Jul 13, 2003 08:54 PM
