What type of Main/Rod bearings should i use for LS-V ??
Old Apr 10, 2006 | 02:41 PM
SiR Inspired ED7's Avatar
Default What type of Main/Rod bearings should i use for LS-V ??
My brother just got a B18 block & wants to know what kind or type is good for this set up ???
Any info will be helpful Thanx
Old Apr 10, 2006 | 03:08 PM
StorminMatt's Avatar
Default Re: What type of Main/Rod bearings should i use for LS-V ?? (88 Crx Si)
OEM should be fine. The problem is not really a bearing problem, but a rod bolt problem. The stock rod bolts stretch at high RPMs, allowing the bearing to separate from the rod and spin.
Old Apr 10, 2006 | 09:52 PM
Default Re: What type of Main/Rod bearings should i use for LS-V ?? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">OEM should be fine. The problem is not really a bearing problem, but a rod bolt problem. The stock rod bolts stretch at high RPMs, allowing the bearing to separate from the rod and spin.</TD></TR></TABLE>
So what do you recommend?
Old Apr 10, 2006 | 10:16 PM
Malgerus's Avatar
88 Crx Si,
I used standard ACL bearings. They are cheap and economical, and some people swear by them. If I had had the time and money I would have went for OEM honda, but I think the ACL's will be fine. They've lived past 8300 RPM with ARP rod bolts and a balanced bottom end.
I ordered them from Earl off Honda-tech. He was very good about it, got them fast and for a good price
Old Apr 10, 2006 | 10:35 PM
crxnj's Avatar
Default Re: What type of Main/Rod bearings should i use for LS-V ?? (Mr. S)
I also can vouch for the acl bearings..As long as they are within spec..Out of all the engines Ive built only one set was out of spec and I just mix and matched acl and oem bearings..And yeah get some arp rod bolts,,stock rod bolts are known for stretching at higher revs..
Old Apr 11, 2006 | 06:37 PM
Default Re: What type of Main/Rod bearings should i use for LS-V ?? (Mr.speaker)
Ok, so i'm going to pick up some arp bolts. Can the ls rods handle about 8300 rpms safe? how much do ACL Bearings and OEM bearings go for now-a-days?
Old Apr 11, 2006 | 07:49 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so i'm going to pick up some arp bolts. Can the ls rods handle about 8300 rpms safe? how much do ACL Bearings and OEM bearings go for now-a-days?</TD></TR></TABLE>
Yeah ls rods can handle 8300 revs with ease when using the arp rod bolts..
Acl complete bearing kit (main bearings,rod bearings,and thrust washers) go for around $100..Sometimes they have a special for $80..And I believe they are available in different sizes now..Oem bearings are alot more,,I forget exactly but when I went to the dealership a while back they were about $9 each for main and rod bearings for B18 engine..
djrichb20t
Mar 5, 2017 01:12 PM
preluder90
Jan 20, 2014 09:28 AM
Baron55
Aug 28, 2006 12:37 PM
Quiz
Jan 21, 2003 11:31 AM
