who makes a 17mm open ended lug nut?
i wasnt too sure if this was where i should post this question, it had to do with wheels so maybe you guys could help me out.
i just purchased a new set of wheels that comes with special lug nuts that are 17mm and are close ended. problem is my front wheel studs are extended, and also when i try to use my zenki lug nuts i can not fit the 19mm socket.
so my question is, who makes a 17mm open ended lug nut(preferably black). i was looking at muteki and kyokugen but was unsure what size socket they take.
please help me out, TIA!
not sure of the size
however i have a set of muteki open ended i used for a day lol and have them at home
i'll check tonight which size they use
( they come with a socket in the case )
and let u know the correct info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sean »</TD></TR><TR><TD CLASS="quote">if they are 17mm would you want to sell them? also what color are they?</TD></TR></TABLE>
they are blue
i'll let u know later
if u want the specs on them exactly i got them from evasivemotorsports.com in the sponsor section
call them they should have alll the details
they are blue
erikiksaz1
Mar 17, 2004 05:12 PM
