will 215/60r/14's fit on stock steelies? (BFG Drag Radials)
Old Apr 10, 2006 | 12:24 PM
B16Civic93's Avatar
Default will 215/60r/14's fit on stock steelies? (BFG Drag Radials)
like it says will 215 60r 14 fit on stock steelies? if so would i have to worry about anything as far as lowering the tire pressure too much? or any other problems with them?
thanks,
Old Apr 10, 2006 | 01:26 PM
Voyage34's Avatar
Default Re: will 215/60r/14's fit on stock steelies? (B16Civic93)
the bfg drag radial in that size has an approved rim width range of 6-7.5.
im pretty sure steelies are 14x5.5, so no i dont think it will fit properly
Old Apr 14, 2006 | 11:48 AM
B16Civic93's Avatar
Default Re: will 215/60r/14's fit on stock steelies? (Voyage34)
well the 205/50r 14 should fit the rim right though correct?
Old Apr 17, 2006 | 02:27 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16Civic93 &raquo;</TD></TR><TR><TD CLASS="quote">well the 205/50r 14 should fit the rim right though correct?</TD></TR></TABLE>
You can look up the specs on the BFG website or the website of a tire dealer like the Tire Rack. If you do that, you will find that the 205/50-14 BFG DR is approved for rim widths of 5.5-7.5 inches.
butter99
Aug 5, 2007 07:28 PM
Will_H
Oct 2, 2006 06:57 PM
Quad-Damage
Apr 17, 2006 03:27 PM
typesguy
Mar 8, 2004 02:29 PM
