question about gas
ok so i just put seven dollars in my tank and the needle was still in the red like barely i mean barely above it i mean i got like 2 to 3 gallons cant rember so i wuld atleast think it would be a quarter full so is my gas gauge thing messed up or wat else can it be
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Concept Tuning »</TD></TR><TR><TD CLASS="quote">Just fill up and see how it moves.</TD></TR></TABLE>
well i would atlest think seven dollars would move it up a quarter of a way so i think it is messed up cause five fills my bros halfway and **** lol
Gas is measured in gallons (or liters or any other unit of volume), not dollars. If you say you put $5 in your tank, that doesn't mean **** because if your gas happens to be $1.50 a gallon that is quite different then, say, if I got $5 worth of gas at my local gas station for $2.60 which is about what it is now. I believe the CRX has an 11 gallon gas tank. I just put 9.06 gallons in mine and the needle was on E, but from what I've been told, the needle will drop below the E well before you're out of gas. There's no low fuel light though so be careful.
civiccrazy93
Nov 16, 2004 12:06 PM
