installation of 98-01 jdm cluster
please help. I need to find out on how to install a JDM ITR 98-01? where are the screw, approximate completion time, and the difficulty level. please help.. anyone, thanks
I could probably do it in 5 minutes.....but you havent told us what year/model is your car....
There's been a few threads in the past that discuss how to do this. One screw in the black guage bezle, pull that out, one screw on the far left/far right, top middle of the gauge cluster, pull out, undo plugs...
whoops you are right. i have a 4 door ls 2000 integra. still has usdm, and I want to install the jdm itr cluster.. is all the screw accessible?
5 screws for the speedo cluster..
lower you steering wheel there is 2 phillps on the black plastic.
slide the plastic trim out..
one screw on the left and one on the right.
one more up right in the middle.
pull out the cluster out gently and remove the plugs ..
I have an integra automatic 98 with a manuel swap obd1
i want to put the 96 JDM spec cluster in my integra what i need to do??? thank you
my black piece of trim didn't come right out as easily as everyone said... but then again I was scared to break it so just that part alone took me about 5-10 min.
This is what I used... it's a guide for removing cluster/replacing the bulbs in the gauges: http://www.team-integra.net/se...D=313
So just to rcap since I ran into this as well, the cluster is duh to remove, as far as the printed circuit on the back of the two clusters, you DO swap them and the ABS contact as well? also the purple voltage regulator on back, swap it as well? Good to hear I do not have to re-pin the plugs sheesh. Thanks again. Stevo
JDM SiR-G/Si-VTEC cluster front and rear :
. and if you cant do this you should change hobbies
