87 Crx SI in south carolina 900.
black 5spd, good paint, new performance ~200hp clutch, repainted amature job on hood and header panel, cracked plastic at the bottom trim in some places and needs front fenders (old plastic ones were cracked up so i junked them)
engine has 220k but 182-185 compression all across which is factory stock so it may have been rebuilt.
also... I have all of the parts you need to turbocharge this car other than the turbo itself, mine is off an svo and is meant to be mounted horizontal not vertically. (it'd be great for an rx7 but not a crx, yes you can have it to) the car with all of the turbo parts is 1500 but the car itself can be had for 900
you could drive this car home (anywhere now that it's got a clutch) and with some engineering and wrench time you could have a 13 second car for 1500 dollars.
http://www.imagestation.com/al...93731
thanks -Josh
sphinxmunkey on aim
telephone 1 803 233 3167
thanks -Josh
sphinxmunkey on aim
Wrong forum Try posting this on http://www.redpepperracing.com
Red86si
Jan 16, 2005 07:02 AM
