Which timing belt do i use? jdm b16 head b18c bottom end
Old Apr 10, 2006 | 09:38 AM
BoRiCuA's Avatar
Default Which timing belt do i use? jdm b16 head b18c bottom end
Which timing belt do i use? jdm b16 head b18c bottom end. I tiried a search but all i found was ls/vtec and b20's. anyways i'll be using the type r water pump on the b18c block, what belt can i use? thanks
Old Apr 10, 2006 | 04:45 PM
rainforest's Avatar
Default Re: Which timing belt do i use? jdm b16 head b18c bottom end (BoRiCuA)
get a type r belt.
Old Apr 10, 2006 | 07:32 PM
Ruben19's Avatar
i have the same set up and i use the GSR belt
B18c1
Old Apr 10, 2006 | 08:38 PM
vteczone's Avatar
Default Re: (Ruben19)
gsr or b16b.
Old Apr 11, 2006 | 02:02 AM
rainforest's Avatar
Default Re: (vteczone)
No A type r will work and its cheaper than a b18c1 belt and a b16a belt will not work due to the differance in the deck height between the 2 blocks.
Old Apr 11, 2006 | 04:13 AM
hatchonarun's Avatar
Default Re: (rainforest)
gsr belt got d same set up
03EM2guy
Aug 27, 2010 07:11 PM
MainStreamHonda
12
Aug 25, 2009 10:08 PM
zacatkings
May 6, 2008 06:51 AM
HondaS2000
Jul 13, 2006 02:11 PM
Ruben19
Dec 23, 2005 05:04 PM
