does taking out the thermostat cause the water temp cel to turn on?
Old Apr 10, 2006 | 07:46 AM
iRIDEdumped's Avatar
Default does taking out the thermostat cause the water temp cel to turn on?
dumb quick question. if i take out the thermostat and leave it out will the car throw a code 6 for the water temperature sensor?
Old Apr 10, 2006 | 07:47 AM
AnthraxVX's Avatar
Default Re: does taking out the thermostat cause the water temp cel to turn on? (iRIDEdumped)
well, i know that when i went from my ls to gsr motor they relocated the water temp sensor to the thermostat, maybe u didnt or forgot to hook it back up?
Old Apr 10, 2006 | 07:50 AM
i hooked it back up, but i had to manually pin both wires into the sensor, cuz i broke the clip, so im thinking either its wired up backwards, a wire is loose, or it just throws the cel 6 if i leave the thermostat out.
miT
Aug 26, 2006 11:38 AM
BrokenHatch
12
May 31, 2005 05:26 PM
PisJDM
May 17, 2005 02:10 PM
