Quick question about pulling cylinder head
Old Apr 10, 2006 | 06:19 AM
Ed 341's Avatar
Default Quick question about pulling cylinder head
I'm removing my cylinder head for a refresh/rebuild and I'm following the manual, but is it completely necessary to remove the timing belt entirely, or just remove the cams/gears from under it?
I haven't attempted to do ether yet so I thought I'd try to get some advice from someone who has done this before I try. A quick explaination would really be appreciated.
Old Apr 10, 2006 | 06:20 AM
Dave_B's Avatar
You can do it either way, the trick is getting the car back in time when you put it back together.
Old Apr 10, 2006 | 06:23 AM
Ed 341's Avatar
Default Re: (Dave_B)
I set it at TDC. Will I need to do anything else to set the timing, if I replace everything just as I found it? Thanks for the quick reply
Old Apr 10, 2006 | 06:25 AM
Dave_B's Avatar
If you have a helms, it should have a step by step procedure to ensuring your putting the car back in time properly. Do you have adjustable cam gears or stock ones?
Old Apr 10, 2006 | 06:27 AM
Ed 341's Avatar
Cams/gears are stock. I looked through the reinstallation but thought the steps may be different if I remove the cams without removing the timing belt.
Old Apr 10, 2006 | 06:42 AM
Dave_B's Avatar
It should pretty much be the same if you left the belt on the crank pulley, or pulled it entirely.
Old Apr 10, 2006 | 06:43 AM
Eva01's Avatar
No, it's not necessary to completely remove the timing belt. I assume you want to avoid pulling off the crank pulley and what not.
You can losen the timing belt tensioner and that should give you enough slack to pull the timing belt off the cam gears.
Old Apr 10, 2006 | 06:53 AM
Ed 341's Avatar
Default Re: (Eva01)
Excellent. Thanks guys. Putting it back together seems a much less daunting task now
Old Apr 10, 2006 | 11:01 AM
mstewar's Avatar
Default Re: (Ed 341)
it's really not that much harder to just go ahead and take it off.. and then you can guarantee you don't have the timing belt on the wrong way below..
Bernalx713
Mar 26, 2014 12:04 PM
xxxmikenicexxx
Jun 17, 2010 05:54 PM
Secret Chimp
Jan 27, 2008 04:44 PM
boomersz
Apr 5, 2007 11:14 PM
boomersz
Apr 5, 2007 09:33 PM
