CRX rear caliper replacement, same as DA integra?
My LR caliper seized up and I went to the junkyard and pulled one of a DA integra. They look the same.... but does anybody know if they <U>are</U> the same?
Im thinking it will bolt right on, but i heard the DA rear brakes are an upgrade.
If its like the front where they look almost identical bolt the bolt holes are further apart, then no it won't work. I'm also curiouse to know for sure though.
the calipers work and fit...but, the pistons are a little bit bigger than the crx; im not sure if you need to use a different rear pad...
they should be completely the same.
the calipers have the same part number and designation, pads are the same, and so are pistons.
ive never tried it myself, so i cant say for certain, but the part numbers match up except for the rotor, which we know the hub is different because of the offset anyway.
im pretty confident enough tho to recommend doing it, and would like to know from you if it works fine once youve done it to confirm.
http://www.norcalcrx.org/tyson/brakepartslist.xls
rice4life
Aug 12, 2015 08:35 PM
EFOSV.
Aug 31, 2007 03:01 PM
george34
Feb 26, 2006 03:11 PM
