valve cover is all oily. leaky o-rings?
Old Apr 9, 2006 | 10:00 PM
budget's Avatar
Default valve cover is all oily. leaky o-rings?
my valve cover lately on my freinds and i has gotten SOME oil on it, not spilled by me. is it leaky o-rings? but on his car the spark plugs got all oily too we know that is leaky o-rings but what causes the valve cover to get oily
Old Apr 9, 2006 | 11:33 PM
E46Kid's Avatar
check the valve cover gasket first
Old Apr 10, 2006 | 08:39 AM
budget's Avatar
Default Re: (EkSi)
thanks, anyone else?
Old Apr 10, 2006 | 10:11 AM
HatchSpeeD's Avatar
Which side of the VC?
Check VC gaskets, spark plug Orings...
If its on the side, cam cap seals, dizzy seal, cam gear seals...depends
Old Apr 11, 2006 | 05:33 PM
budget's Avatar
Default Re: (HatchSpeeD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchSpeeD &raquo;</TD></TR><TR><TD CLASS="quote">Which side of the VC?
If its on the side, cam cap seals, dizzy seal, cam gear seals...depends</TD></TR></TABLE>
there is some on the top left side of the VC by the oil cap and some by where the spark plugs are (gsr motor)
Old Apr 11, 2006 | 05:56 PM
HatchSpeeD's Avatar
Make sure its not spilled oil from pouring into oil cap If not, left side would be dizzy seal or cam cap end sealamajiggy. If you wanna dot your i's & cross your t's, just get a new upper gasket set. Not that bad of a installs, VC gastket, spark plug orings, dizzy seal, cam cap seal, cam gears seals....should be good.
Lowassteg
Dec 23, 2015 07:15 AM
boostedegls
Aug 5, 2009 11:15 PM
black0hatch
Apr 6, 2008 12:51 PM
krz6jdm
Apr 7, 2006 06:36 PM
si foo
Apr 27, 2002 06:32 PM
