Fireplug's Drag 240sx
Old Apr 9, 2006 | 09:20 PM
Fireplug's Avatar
Default Fireplug's Drag 240sx
New here, just thought I'd share my car with you guys.
Car: 1993 Nissan 240sx (base model)
Tires: Mickey Thompson 255/50/16's and Hoosier 27x10.5 Quicktime pros
Engine: Redtop SR20DET
Complete Mod list:
<u>Performance Modifications to the car and motor</u>
BLOCK[*] Cleaned/magnafluxed[*] Decked[*] Balanced[*] Bored .040 over and powerhoned[*] Crankshaft has been micropolished[*] Wiseco pistons (9.0:1 compression) (87mm)[*] Eagle rods[*] ARP Main stud kit[/list]HEAD[*] ARP Head stud kit[*] Power Enterprises 1.5mm metal headgasket[*] Ferrea double-valve springs,titanium retainers, seats[*] Tomei Rocker Arm Stoppers[*] HKS 272 Step 2 cams[*] HKS Adj. cam sprockets[*] Competition 5-angle valve job w/ radius entry[/list]ENGINE MODS[*] Precision PT67 Turbo[*] SST stainless top-mount manifold[*] SST stainlesswastegate dump tube[*] SST 3.5" stainless downpipe[*] 4" stainless intake pipe w/ K&N filter[*] Tial 40mm wastegate with 1.0 bar spring[*] Tial racing blow-off valve[*] Blitz LM Front mount Intercooler kit (modified coldpipe)[*] SST custom hot pipe[*] KOYO radiator [*] FAL dual 12" FAL fans[*] Greddy intake manifold[*] Greddy Catch can
Fuel Delivery/Ignition setup:[*] SST fuel rail (top feed) with -8 fuel fittings[*] MSD top feed 96/lb injectors[*] Aeromotive FPR[*] -8 Teflon Stainless Braided Fuel Feed line[*] -6 Teflon Stainless Braided Fuel Return line[*] Twin Walbro 255lph fuel pumps (2nd wired to kick on via AEM)[*] AEM EMS
Drivetrain:[*] vlsd[*] Chromemoly 4340 Stage 3 axles (LS auto)[*] Mickey Thompson ET streets (255/50/16)[*] SPEC stage 3 clutch[*] Fidanza Lightened flywheel[*]Driveshaft safety loop
Suspension/Brakes/Wheels:[*] Buddyclub P1 wheels (16/7.5 fronts, 16/8.5 rears)[*] Tein HE coilovers[*] Whiteline polyurethane bushings (upper/lower links, subframe spacers, TC, etc.)[*] front/rear strut tower bars[*] 300zx master cylinder[*] 300zx 30mm calipers[*] Brembo slotted 300zx front rotors [*] Brembo slotted rear rotors[*]Stainless steel brake lines (PDM racing)[*]EBC green pads[/list]
Old Apr 9, 2006 | 09:30 PM
delspool's Avatar
Default Re: Fireplug's Drag 240sx (Fireplug)
nice looking car and setup
Old Apr 9, 2006 | 09:41 PM
Universal Magnetic's Avatar
Nice clean setup you got there...It's finally nice to a see a DRAG style 240....Post some track times
Old Apr 9, 2006 | 10:09 PM
jarel's Avatar
Default Re: Fireplug's Drag 240sx (Universal Magnetic)
clean 240.....what times are you aiming for?
seems to be alot more drag 240s coming out
Old Apr 10, 2006 | 09:20 AM
dunkd's Avatar
looks mean w/ those radials on the back! what kinda numbers is it making?
Old Apr 11, 2006 | 07:53 PM
Fireplug's Avatar
Default Re: (dunkd)
Well, the car is making 500whp (mustang dyno) right now at 21 psi on a T4 PT67, the clutch wouldn't allow us to crank the boost any higher. It only made it to the track once where it made three passes. All were made at 18 psi without a 2 step, no burnout, and fouled plugs. It ran an 11.5 @ 125 with a 1.9 60'. I'm doing some new stuff for this season and hoping to get a lot more seat time at the track. I'm going to attempt to run 10's on 18 psi. Once this is achieved I will turn the boost back up and shoot for faster times.
-Aaron
Old Apr 11, 2006 | 08:48 PM
paulzy's Avatar
Damn, that **** is hot. My inlaws live in Omaha. Maybe next time I come down we can grab a few
Old Apr 12, 2006 | 05:55 AM
99lspwr's Avatar
Default Re: (paul vang)
Very clean setup there... from me all the way..
Old Apr 12, 2006 | 07:50 AM
adrenalinjunkie's Avatar
Default Re: (rota92)
I like clean cars.
Old Apr 17, 2006 | 02:19 PM
Fireplug's Avatar
Sounds like a plan, just shoot me a PM!
Old Apr 17, 2006 | 02:28 PM
ChicagoMike's Avatar
Default Re: (Fireplug)
Nice *** 240!!
Old Apr 17, 2006 | 07:57 PM
busted-B18's Avatar
yeah u can pull 10's easy with 18psi. I think this is one of the sexiest 240 ive seen and its done right. props to u brotha.
Old Apr 17, 2006 | 08:11 PM
Jokerluv's Avatar
very nice and clean
Old Apr 17, 2006 | 09:20 PM
.dave's Avatar
i HAS questions ?
Default Re: (Jokerluv)
Nice car.
lol Omaha. How's the school district out there going?
Old Apr 18, 2006 | 08:37 AM
10sec PRO-AM's Avatar
nice car what transmission are you using?
Old Apr 18, 2006 | 10:23 AM
Fireplug's Avatar
Default Re: (daveG)
I appreciate the compliments guys, thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daveG &raquo;</TD></TR><TR><TD CLASS="quote">Nice car.
lol Omaha. How's the school district out there going? </TD></TR></TABLE>
Haha, it doesn't concern me...I'm in college.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10sec PRO-AM &raquo;</TD></TR><TR><TD CLASS="quote">nice car what transmission are you using?</TD></TR></TABLE>
Excellent question...I WAS running the SR transmission, it only took one pass at the track to change that situation. This season I will be running a 300zx transmission mated to the sr20det, they're beefier and seem to be working perfect on other 240sx's.
Note: These pictures are not on my vehicle, I don't want to take someone elses credit for those pictures.
Old Apr 18, 2006 | 10:32 AM
dk-fabrications's Avatar
very nice setup
Clean look !!!
Old Apr 18, 2006 | 11:00 AM
Default Re: (dk-fabrications)
The 300zx tranny is a great tranny to go with.
I have heard alot about this setup and people have been very happy with it !!
Old May 12, 2006 | 03:26 PM
Fireplug's Avatar
If you didn't know already...SPEC clutches are ****. (imo) After less than 1000 miles it's almost completely gone! It didn't even hold up to a dyno session. It was at the dyno once, the track once (3 passes) and a few street jonts...here's the aftermath:
Some new **** for 2006:
New motor setup:
[*]Carrillo H-beam Rods
[*]CP Pistons: 9.0:1 cr
[*]ACT StreetLite Flywheel
Other new mods (no pictures though) include:[*]RPS TurboMax 6 Puck clutch[*]Mazworx 300zx transmission adapter kit (short shifter & 1-piece driveshaft)[*]Line lock kit[*]5 Lug conversion[*]FD RX7 wheels[*]Nismo Motor and Transmission mounts[*]Power Enterprise 1.1mmx87mm Headgasket[*]60mm extended wheel studs[*]H&R spacers
Hopefully I'll have the motor back from the machine shop by next Tuesday...I'm aiming to have the car running by May 30th. We'll break in the new motor setup, and turn the boost up to 35-38 psi...See if we can't just break past the 700whp mark.
Old May 12, 2006 | 04:26 PM
Turbocivic94's Avatar
Clean 240
Old May 12, 2006 | 10:40 PM
bs-inc's Avatar
Default Re: Fireplug's Drag 240sx (Turbocivic94)
Are you going to be here for Import Face Off in Kansas City on the 21st?
Old May 17, 2006 | 02:45 PM
Fireplug's Avatar
Default Re: Fireplug's Drag 240sx (bs-inc)
Highly doubtful, I'm getting the motor back in a few days...then I've still got a transmission kit to install...after that the motor needs to be broken in...and a cage needs to be installed! So it's not looking too promising for the 21st.
Old May 17, 2006 | 05:18 PM
hybridcivicex's Avatar
how do you like the AEM EMS?
Old May 17, 2006 | 07:29 PM
Mazworx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fireplug &raquo;</TD></TR><TR><TD CLASS="quote">I appreciate the compliments guys, thanks!
Note: These pictures are not on my vehicle, I don't want to take someone elses credit for those pictures.</TD></TR></TABLE>
Wow, that's a pretty neat set-up with the 300zx trans. Where can I get one?
Old May 20, 2006 | 02:21 PM
Fireplug's Avatar
Default Re: (Mazworx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridcivicex &raquo;</TD></TR><TR><TD CLASS="quote">how do you like the AEM EMS?</TD></TR></TABLE>
No complaints so far, it's done everything I hoped it would and hasn't caused me any problems!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mazworx &raquo;</TD></TR><TR><TD CLASS="quote">Wow, that's a pretty neat set-up with the 300zx trans. Where can I get one? </TD></TR></TABLE>
That's a damn good question! I called on Friday and couldn't get mine! You guys were out of town racing your car!!!! I'll be giving you a call on Tuesday (when you return) and placing my order.
