problems, problems..and more problems...on fuel injection
ok..here's the deal, 89 civic hb si, freshly build motor, turbo charge, the car been sitting for almost a year, since the rebuild of the motor, the car ran fine and everything work perfectly. After the i install the motor in, the car won't START...I check like everything, i have spark. the only thing i don't have is fuel. I thought it was the fuel pump, but i drop the tank and took it out. i jump the fuel pump and it works...what the heck...got to put it back...the thing is that the main relay started clicking and i bought a new one from the dealer, plug it in and still don't work...after awhile it started clicking too...i check both relay like the chilton book said, both works like they said in there. after that i'm lost ...any help will be good...also any one know here to find a service manual for the car online...?? I found so along time ago but now i can't find any.....
does the main relay start clicking as soon as you try to start it. if so, then its the ground that grounds the main relay, ecu ect. it is on the engine harness and bolts up to the thermastat housing. should be to brown? wires and one connector that a bolt goes through.
hope this helps
hope this helps
Si-Samuri
29
Jun 19, 2008 05:48 PM
