recap of last year with my del sol - video
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type Gendy »</TD></TR><TR><TD CLASS="quote">type gendy: nice vid
type gendy: no ******* tho</TD></TR></TABLE>
Hahahaha
Hahahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12SEC CIV »</TD></TR><TR><TD CLASS="quote">
oh tim, it's okay...
</TD></TR></TABLE>oh tim, it's okay...
Was that actual horsepower?Seems like you'd run a little faster if it was. For that dyno, weren't the rpm's messed up and showed you under revving? That would lead to incorrect readings. If I'm wrong, my bad...just curious, however, curiousity killed the cat lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PA MATT »</TD></TR><TR><TD CLASS="quote">Was that actual horsepower?Seems like you'd run a little faster if it was. For that dyno, weren't the rpm's messed up and showed you under revving? That would lead to incorrect readings. If I'm wrong, my bad...just curious, however, curiousity killed the cat lol</TD></TR></TABLE>
it was on a mustang dyno that used MPH as a pickup across the RPM axis, instead of using a spark plug wire rpm hookup. If the MPH wasn't calibrated dead on then the rpm range would be off. Car was dyno'd for free so can't complain. The car was rev'd out to 8k so it is accurate.
Also its 189whp with some non natural aspiration
I think her times were pretty good for basically a stock b16 w/ a 55shot. She was able to pull a 2.1 60'... sure some room for improvement, but good none the less to me. Her best was a 14.1 @ 98mph.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">it was on a mustang dyno that used MPH as a pickup across the RPM axis, instead of using a spark plug wire rpm hookup. If the MPH wasn't calibrated dead on then the rpm range would be off. Car was dyno'd for free so can't complain. The car was rev'd out to 8k so it is accurate.
I think her times were pretty good for basically a stock b16 w/ a 55shot. She was able to pull a 2.1 60'... sure some room for improvement, but good none the less to me. Her best was a 14.1 @ 98mph.</TD></TR></TABLE>
you forgot the fact that i am a stupid girl and can't drive anyway
to the best girl driver on H-T
