Overflow tank
Old Apr 9, 2006 | 03:50 PM
DFW's Avatar
DFW
Default Overflow tank
Looked at my overflow tank the other day and it was a lil passed max so I dumped out some to where it was in the middle of Min and Max and drove around for a little while and my car feels like it's about to die when come to a stop. It starts idleing real low if I don't turn on the heater.
Do I just need to flush/bleed the radiator or is there another problem?
Old Apr 9, 2006 | 03:54 PM
De_tour's Avatar
Default Re: Overflow tank (DFW)
did u check your radiator fluid level?
Old Apr 9, 2006 | 04:04 PM
DFW's Avatar
DFW
Default Re: Overflow tank (wspcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic &raquo;</TD></TR><TR><TD CLASS="quote">did u check your radiator fluid level?</TD></TR></TABLE>
How do I do that?
When I opened the cap this morning (haven't been driving since last night) some came out. After I got back from driving, it was at Max again on the overflow tank.
Old Apr 9, 2006 | 04:26 PM
De_tour's Avatar
Make sure your motor is cool, take off the radiator cap with a rag and look in there to see if the fluid is at the top. If you cant tell, stick your finger in there to feel if its above the core. If its not top it off.
and what do u mean some came out? like when u took the cap off the radiator it overflowed?
Old Apr 9, 2006 | 04:28 PM
donvito#1's Avatar
it sounds like a bad thermostsat also is your car over heating at all
Old Apr 9, 2006 | 04:29 PM
De_tour's Avatar
Default Re: Overflow tank (donvito#1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donvito#1 &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like a bad thermostsat also is your car over heating at all </TD></TR></TABLE>
how so?
Old Apr 9, 2006 | 04:33 PM
donvito#1's Avatar
well i was just making a sugg didnt know if car is over heating or not
Old Apr 9, 2006 | 04:40 PM
De_tour's Avatar
hmm thats true, my overflow tank is always empty though. and i never have a problem.
Old Apr 9, 2006 | 04:47 PM
d16Booger's Avatar
When the fluids were replaced were they placed in the radiator not the overflow?
Old Apr 9, 2006 | 04:59 PM
DFW's Avatar
DFW
Default Re: (d16Booger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your motor is cool, take off the radiator cap with a rag and look in there to see if the fluid is at the top. If you cant tell, stick your finger in there to feel if its above the core. If its not top it off.
and what do u mean some came out? like when u took the cap off the radiator it overflowed?</TD></TR></TABLE>
Yeah, when I took off the radiator cap some came out.
The temp gauge says at normal even when my car feels like it's about to die. It drops down to like 200 rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16Booger &raquo;</TD></TR><TR><TD CLASS="quote">When the fluids were replaced were they placed in the radiator not the overflow?</TD></TR></TABLE>
Replaced? I never touched the radiator or the overflow tank before.
Old Apr 9, 2006 | 05:06 PM
De_tour's Avatar
Default Re: (DFW)
pop the plug, drain the radiator, empty your overflow, then fill your radiator with that 50.50 antifreeze and see how it is from there.
you might have bad fluid, and it dosent hurt to get new stuff in.
Old Apr 9, 2006 | 05:10 PM
DFW's Avatar
DFW
Default Re: (wspcivic)
Yeah I was guna do that, just seeing if anything else could be the problem.
Old Apr 9, 2006 | 05:39 PM
De_tour's Avatar
Default Re: (DFW)
what about your injectors? or intake manifold? dirty?
Old Apr 9, 2006 | 08:05 PM
DFW's Avatar
DFW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic &raquo;</TD></TR><TR><TD CLASS="quote">what about your injectors? or intake manifold? dirty?</TD></TR></TABLE>
When I first got the car it was covered in dirt, like layers inside and out of the car. I cleaned it up but there's still dirt around the injectors and IM.
Old Apr 17, 2006 | 09:51 PM
DFW's Avatar
DFW
Default Re: (DFW)
Dumb question but are you supposed to put water or radiator fluid in the overflow tank? Or anything at all?
DC4 ENTHUSIAST
Oct 30, 2008 08:50 PM
touandcim
19
Mar 11, 2008 10:10 AM
wastro
Dec 10, 2005 12:02 PM
jeffb16
May 31, 2004 08:43 AM
Chip398193
Nov 1, 2003 10:01 PM
