need to know the main diffrences between a y8 and z6
i need to know the main diffrences between the bottom ends in the y8 and z6? i found a short block from a z6 that i would like to use in place of my y8. i was going to keep my y8 head and manifolds, but i wasnt sure if all my accesorys would bolt up. i would like to keep my power steering and ac. the only reason i would like to use the z6 short block is that its only going to cost me 75 bucks. the crank from my y8 is shot and im on a very limited budget. will the z6 work for me or do i keep looking? thanks.
Yeah, that's a real good setup. Z6 block is better than Y8, but the y8 head is pented which is a little better. Everything should bolt up if you have all the brackets ect. Good Price, good luck with it.
