SHIT TON OF PARTS Honda-Acura-Integra-DA-OBD1-Injectors-ITR-you name it
All parts are located in Colorado, you pay for shipping.....Shipping quotes will be made when requested parts are made.....
Here we go...
98+ front bumper, with emblem holes shaved, as well as "Integra" shaved....SOLD
A-pillar faux CF gauge cluster for a Integra...not sure what else it will fit...$20
Stock clutch, pressure plate, and FW out of a 99GSR....still has LOTS of meat left if you end a cheap clutch.....$50
OEM GSR front upper strut bar...needs paint...$20
VERY clean rear hatch cover for a G3....out of a 98 ITR...$40
Center console out of a 94LS....$15
Stock turnsignals for a 94-97 Integra....$10
B-series starter.....SOLD
B-series OBD1 FITV....in PEFECT shape.....$40
Various B-series motor mounts...polished drivers upper side...$60 for all including inserts....
B-series tranny support brackets.....LS motors DO NOT have these, adds structure between the block and tranny...$20
*edit* LS's do have the bigger bracket, the smaller one is found on GSR/ITR's*
Perfectly working B-series alternator.....not pretty looking, but works perfect...SOLD to lhddc4....good buyer!
OBD1 LS dizzy.....bought roughly 2 years ago new from Distributor Kings..SOLD to Stevn....good buyer!
Black carpet set out of a 1998 Type R......$80
2.5" straight coupler with 2-t-clamps.....$20
OBD1 Injectors out of a 94 LS (240cc), cleaned, includes top pre-filter, good to go.....$40
OBD2 Injectors with clips out of 99 GSR (240cc), cleaned, includes top pre-filter....$50
BRAND NEW fuel filter for 93 Prelude.....$20
OBD1 fuel pressure regulator out of a 94 LS.....$30
OEM MAP sensor, works perfect.....$30
OEM S2000 antenna, with a joiner so that you can do a S2000 Antenna conversion...$20
OEM cam gears out of a 94 LS.....$10
G3 Integra passenger side window roll up controll thingy.....$15
OEM Clutch switch out of a 94 LS....$10
G2 Integra oem deck and cd player....$30
Rear hatch covers for G3 Integra, these cover where the tail lights are...$10
OEM 99 GSR fuel pump, works perfect.....$20
Modified by nicklk at 5:06 AM 4/11/2006
Modified by nicklk at 8:16 AM 4/13/2006
Here we go...
