Hardtop Question. Already searched.
When you put a hardtop on, what happens to the softtop?
Is it removed or just stuck in the down position?
If it is removed, has anyone took out the Motor for it? How much weight did you lose?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StinkyTofu »</TD></TR><TR><TD CLASS="quote">The soft top stays folded down. I took my soft top/motors out and it ended up weighing around 60-65 pounds. </TD></TR></TABLE>
Thanks perfect answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beandip »</TD></TR><TR><TD CLASS="quote">
Your welcome
I forgot to mention that the mugen hardtop weighs 44 pounds and so i saved about 20 pounds. The OEM hardtop is noticeably heavier.
</TD></TR></TABLE>Your welcome
Your welcome
I forgot to mention that the mugen hardtop weighs 44 pounds and so i saved about 20 pounds. The OEM hardtop is noticeably heavier. </TD></TR></TABLE>
And I always had trouble believing the OEM top was slightly heavier than the carbon mugen when it felt a lot heavier.
Don't pull out your soft-top and the motors unless you don't plan on every putting it back on. It's a pain in the *** that I'll have to deal with soon, the re-installation of the soft top.
Your welcome
Is there anything necessary to prepare the plastic windows on the ap1 for this? Just seems like having it folded down for a long period of time would be bad for it.
I was wondering the same thing. if the soft top is folded down for extended periods of time, does it get permanently creased? or is it more prone to cracking? I plan on getting a hardtop after the summer, but I was concerned as to how the softtop/rearwindow will be after folded down for such a long period of time...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmorgan15 »</TD></TR><TR><TD CLASS="quote">is it easy to take the hardtop off and drive the car topless? if so how long does it take to take the hardtop off? 5 minutes. 20 minutes?</TD></TR></TABLE>
It takes 10 seconds if you have a friend to help you. If you have the mugen carbon top, 15 seconds and you can do it yourself.
JRizEJ6
Audio / Security / Video
Feb 7, 2006 08:37 PM
