Fully built LS/Vtec [b]COMPLETE[/b] swap for sale
Block, 22,000 miles since build:
1996 b18b (1847cc) complete shortblock: Endyn Rollerwaves, 12.2:1 CR 81.5mm pistons, Eagle rods, Micropolished crank, All new Honda bearings, ITR oil pump, ITR water pump, ITR oil cooler, ITR oil separator box, ITR crank pulley. Spoon oil pan drain plug
Head 12,000 miles on it since build:
JDM B16A mild port. Valve seats and valves were matched with a five angle valve job.
Jun3 cams
Portflow inner valve springs
ITR Outer valve springs
Skunk2 Titanium retainers
ITR intake manifold
65mm bored R throttle body
NGK iridium plugs(2000 miles)
valve cover gasket kit
2000 ITR Distributor
RC 370cc injectors
AEM adjustable cam gears
Type R Fuel Rail
ARP Head Studs
Red valve cover
JDM HKS super header (super rare about 750$+ new)
Hondata S200 with ecu already tuned.
Driveline
2001 JDM ITR transmission LSD
Action 6 puck sprung hub clutch and pressure plate
Clutch Masters 8lb aluminum flywheel
new axles.
This is a complete swap for a EG. (It includes shift linkage, starter, alt etc) I have dyno sheets for 211 whp and 142.3 ftlbs tuned on Dynojet.
$5,000 plus shipping. We are willing to deliver to Seattle for $100, and might go farther for more money.
Modified by Jaker at 11:27 AM 4/9/2006
Jun3 cams
ITR intake manifold
RC 370cc injectors
Type R Fuel Rail
ARP Head Studs
Red valve cover
Driveline
new axles.
Looks interesting. Is this ODB1? Do you have receipts for parts, machine work, labour, etc?
I might scrap my B16 build and just drive up to pick this motor up.
Solo2Vtec
Nov 11, 2004 02:56 PM
TurboDANDEE
Feb 11, 2004 01:09 PM
