Halfshaft bearing info needed
Old Apr 9, 2006 | 05:44 AM
D95si420's Avatar
Default Halfshaft bearing info needed
hey guys i just need to know if all b-series halfshaft bearings are the same. There is not a acura around where i live for 100 miles but i have a honda. I have a b18 in my 91 hatch and the intermediate shaft bearing is about done what i was gonna do is order one for a 95 del sol SI B16 or a 99-00 civic SI. Just wondering if this will work so i dont have to make a long drive fro nothing. Does the seal happen to be the same as well??? also where is the cheapest place to get the Quaife quick ratio manual steering upgrade??? and the best place to get the rebuild kit with seals for the rack, and of course honda has the wonderful rack end bushing us EF owners love
Old Apr 9, 2006 | 05:17 PM
jacoop86's Avatar
Default Re: Halfshaft bearing info needed (D95si420)
http://www.acuraautomotiveparts.org
90 integra intermediate shaft
if your shaft is one from a SiR then you will need a new driver's side axle.
Old Apr 10, 2006 | 12:22 AM
D95si420's Avatar
noe i have a 91 teg intermediate shaft, just checking if the bearing for it is the same for the b16 del sol or civic SI so i can pick it up at honda since i dont have a acura close to me. just need a new bearing pressed in. I know about the sir shaft being different/longer but thats no worry for me cause i am using teg one
Old Apr 10, 2006 | 06:50 AM
jlicrx's Avatar
Default Re: (D95si420)
del sol intermediate shaft bearing has same part number as 91 integra intermediate shaft bearing
91057-SH3-008
Old Apr 10, 2006 | 04:21 PM
D95si420's Avatar
Default Re: (jlicrx)
thank u very much for the info, between work and the side work i have been doing i was not able to call honda today to find out if they were the same. thank god for wonderful honda-tech and all its glory. If i would have searched mor i probly would have found it but thaks for the answer to my ??. Another ? though is can u use a cheap press to pop it in or will it go in pretty easy after u remove snap ring. maybe freeze the bearing overnight and tap in with block of wood possibly. never had to do one myself, usually just got another one from junkyard when they went bad. Want this setup to be brand new cause i am trying to chase down a slight shake i have in the front end. I have replaced everything else except for the rack/inner tie rods. No parts places like my work sell a manual rack so i have to rebuild mine. I am probly gonna get the quaife quick ratio kit for it. does anybody have the seal kit for the rack besides honda??? i know i need the rack end bushing and the nuts on the innter tie rods but was hoping to find a seal kit instead of buying them all individually. sorry for the long post but thanks again.
Old May 23, 2006 | 03:46 PM
ef9ontime's Avatar
i hate to bring this topic out again, but does anyone know if the halfshaft bearing for the 95 delsol(si) is the same for a ys1 trans? I just bought one from honda, cuz mine is making noise and I'd like to know if its the same before I take it apart....
janos
Transmission & Drivetrain
Jun 13, 2013 08:36 AM
rnouri
Honda Civic (2001 - 2005)
Jun 28, 2012 09:50 AM
slooogsr
Apr 3, 2004 07:18 PM
fsck3r
Dec 20, 2002 08:52 PM
