question about dropping the h22 in a 92
Old Apr 8, 2006 | 11:22 PM
19accord92's Avatar
Default question about dropping the h22 in a 92
hi, i was wondering if you dropped an h22 and a turbonetics t3 turbo into a 92 accord, how well it would do, and how much horsepower and torque you would be able to get out of it? considering you only change maybe the cam gears and pulleys and pistons on the h22? the h22 will be comming out of a 92 - 95 prelude ( the ones you always see on ebay ) the ones from japan. i've seen that there are different types of h22, so i was wondering which one was the one with 200 hp ? thanks for input in advance
Old Apr 9, 2006 | 10:54 AM
19accord92's Avatar
Default Re: question about dropping the h22 in a 92 (19accord92)
bump!
Old Apr 9, 2006 | 07:30 PM
gianinline's Avatar
The h22a has 200hp stock, I believe it has 185whp stock. When you add aluminum pulleys to this story, you need to consider how much the pulley set weights against the stock ones, which are heavy.
You will gain a certain amount of hp to the crank at every 1lb of weight removed.
Old Apr 9, 2006 | 07:33 PM
gianinline's Avatar
I believe you can a maximum of 10 psi on a stock F22, but you cannot put 10psi on a H22 without doing some work on the internals.
Not sure if 8psi or 9psi is what is safe to go with stock.
Old Apr 9, 2006 | 07:38 PM
gianinline's Avatar
Reason why H22 is not so much of a "boost friendly" motor is because of its compression, and its piston rings.
You can use a F22 block instead of the H22 one, that's what is called "g22" series.
Do some research and you will get more answers.
95accordh22a
Mar 12, 2005 05:26 PM
DV98CVC
Mar 11, 2003 09:18 PM
Kp_VtekNiks
Feb 3, 2003 07:20 PM
